Re: Carb "air screen" for track-only use?
[Re: BloFish]
#962991
03/31/11 10:13 PM
03/31/11 10:13 PM
made this one myself about 35.00
MOPARCHAS Where did you get the bases from? Very nice job you did.
I would think that finding the base is half the battle
Well you gotta start somewhere. ![](/ubbthreads/images/graemlins/laugh2.gif)
#962992
03/31/11 10:55 PM
03/31/11 10:55 PM
Posts: 7,506 Az
Crizila
Az
Never bought in to the screen thing much. When I have to run at a dirty track, I do this:
Fastest 300
[Re: MRMOPAR622]
#962994
03/31/11 11:43 PM
03/31/11 11:43 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Any kind of filter at all would hurt the air flow,hurt the hurt air flow kill the HP. ![](/ubbthreads/images/graemlins/grin.gif) On a street/strip car Yes I see a need for one.
I'm sure at some power level the air filter does become a restriction...but I've tested on a dyno up to about 600 hp with and without a 3" K&N style air filter with a drop base on multiple occasions and found no power loss with the filter.
[Re: Quicksilver440]
#962996
04/01/11 09:53 AM
04/01/11 09:53 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Did you re-jet to see if you were at true max power... ALL filters have a restriction its just a matter of how much... I use to flow air cleaners(and the housings) for Chrysler.... we would try different filter elements in the same housing then we would try different shapes of housings... it ALL makes a difference... some are just small differences ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MRMOPAR622]
#962998
04/01/11 10:11 AM
04/01/11 10:11 AM
MR_P_BODY
Sometimes that small difference can be what wins you the race.
Very true if you race all out, but for a bracket racer its not critical... basically the air cleaner/housing is no different than the head port itself... a little shape change here or there makes a difference ![](/ubbthreads/images/graemlins/wave.gif)
