Re: Carb "air screen" for track-only use? #962990
03/31/11 10:02 PM
03/31/11 10:02 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
made this one myself about 35.00
MOPARCHAS
Where did you get the bases from?
Very nice job you did.
I would think that finding the base is half the battle
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Carb "air screen" for track-only use? [Re: BloFish] #962991
03/31/11 10:13 PM
03/31/11 10:13 PM
MOPARCHAS
Well you gotta start somewhere.
Re: Carb "air screen" for track-only use? #962992
03/31/11 10:55 PM
03/31/11 10:55 PM
Az
Crizila Offline
Crizila  Offline
Az
Never bought in to the screen thing much. When I have to run at a dirty track, I do this:
Fastest 300
Re: Carb "air screen" for track-only use? [Re: Crizila] #962993
03/31/11 10:56 PM
03/31/11 10:56 PM
Az
Crizila Offline
Crizila  Offline
Az
Clean track, I do this:
Fastest 300
Re: Carb "air screen" for track-only use? [Re: MRMOPAR622] #962994
03/31/11 11:43 PM
03/31/11 11:43 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Any kind of filter at all would hurt the air flow,hurt the hurt air flow kill the HP.
On a street/strip car Yes I see a need for one.
I'm sure at some power level the air filter does become a restriction...but I've tested on a dyno up to about 600 hp with and without a 3" K&N style air filter with a drop base on multiple occasions and found no power loss with the filter.
Re: Carb "air screen" for track-only use? [Re: Quicksilver440] #962995
04/01/11 09:27 AM
04/01/11 09:27 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Not sure if I will ever "run" w/out the filter,the thought of a small bird or something getting sucked in stresses me
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Carb "air screen" for track-only use? [Re: Quicksilver440] #962996
04/01/11 09:53 AM
04/01/11 09:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you re-jet to see if you were at true max power...
ALL filters have a restriction its just a matter
of how much... I use to flow air cleaners(and the
housings) for Chrysler.... we would try different
filter elements in the same housing then we would
try different shapes of housings... it ALL makes
a difference... some are just small differences
Re: Carb "air screen" for track-only use? [Re: MR_P_BODY] #962997
04/01/11 10:05 AM
04/01/11 10:05 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Sometimes that small difference can be what wins you the race.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Carb "air screen" for track-only use? [Re: MRMOPAR622] #962998
04/01/11 10:11 AM
04/01/11 10:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Very true if you race all out, but for a bracket racer
its not critical... basically the air cleaner/housing
is no different than the head port itself... a little
shape change here or there makes a difference
Re: Carb "air screen" for track-only use? [Re: Dads426] #962999
04/01/11 12:14 PM
04/01/11 12:14 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
My garage/trailer queen has a couple of those Mopar horns. Chrysler engineers used to recommend these, however I notice that no SS/AH cars run them. I have always wondered if they restrict flow. I do think that they lower the stress level when you leave your car unattended.
Moparchas = Very nice pieces, nice workmanship.
Re: Carb "air screen" for track-only use? [Re: RAT PATROL] #963000
04/01/11 01:26 PM
04/01/11 01:26 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
my screens seem just fine around where I live. Not much dust and gravel in PA....rains too much!
I've had the engine apart a few times and no wear that is any more than anything else. Carbs stay clean too.
One thing that helps is that I don't have a hood scoop. Flat hood. Car runs just fine at the track and gets about 1000miles a year put on. This engine is about 8 years old now.
