Holley tuning help #962250
03/30/11 12:57 AM
03/30/11 12:57 AM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I have a 1985 w150 with a 318 that has a 650 double pumper, edelbrock air gap and headers with a full three inch exhaust, other than that it's stock. Im getting a very bad bog starting off and if I floor it the truck will stall. I have to feather the gas to get it moving and the it runs ok. I checked for accelerator pump shot and I get a shot as soon as I hit the throttle. The timing is at 14 inital and 34 total. I just swapped to the four barrel and am trying to get it sorted out. Any help appreciated.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Holley tuning help [Re: 73cuda340] #962251
03/30/11 07:50 AM
03/30/11 07:50 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Check for vacuum leaks.
Re: Holley tuning help [Re: ireland383] #962252
03/30/11 07:58 AM
03/30/11 07:58 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
having to feather it, as in, pumping the gas when starting off? sounds like you need MORE pump shot.
I would start out by changing the size of the nozzle on the pump shot, one or 2 sizes bigger so that you get more fuel, faster. then you can start playing with the cams on the pump shot too if you need more duration of pump shot.
I had the same problem on a holley DP. I had to pump the gas 3 or 4 times to get the RPMs up without stalling it. went up a few sizes in nozzle, and also changed the cam so that I got a longer duration shot, and the problem went away
**Photobucket sucks**
Re: Holley tuning help [Re: 70Cuda383] #962253
03/30/11 10:18 AM
03/30/11 10:18 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Are you sure the carb is clean and adjusted?
What jets are in it? What is the list number?
Re: Holley tuning help [Re: fox] #962254
03/30/11 10:38 AM
03/30/11 10:38 AM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
Off-idle bogs often mean that you're running rich. You need to make sure that 1. you're idle mixture screws are adjusted properly 2. you have correct power valves, and 3. your jetting is right. The first two things can be done with a vacuum gauge and a little patience. The third requires trial-and-error and a lot more patience.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Holley tuning help [Re: fox] #962255
03/30/11 10:45 AM
03/30/11 10:45 AM
crlush Offline
crlush  Offline
My opinion, heavy truck, stock 318, stock converter and prob. 3.23 gear, and too much carb for your combo, a 600 vac would be a better choice, what size squirters do you have? I would try some different squirter pump cams (slower ramp) and some smaller squirters. After you sort that out you will most likely need to jet it down depending on what you have in there now to help your mid and top end.
Re: Holley tuning help [Re: fox] #962256
03/30/11 01:09 PM
03/30/11 01:09 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I agree, I wouldn't start changing pump cams & squirters, The carb needs to be checked for dirt in the bleeds, jet sizes/bad PV ect., That carb should work damn near flawless with OOTB settings on a mild SB.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Holley tuning help [Re: 70Cuda383] #962257
03/30/11 01:16 PM
03/30/11 01:16 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Sounds like the carb had internal issues, maybe even vacuum leaks & you did a "bandade" fix, unless you had a high dur. cam & low manifold vacuum, there should be no reason an OOTB holley (properly sized) should need any more then Idle screw adj. & maybe a minor jet change, even with high dur. cams/low man. vacuum i can tune in a holley with minimal changes in squirters/cams IF the timing curve is set right.
Re: Holley tuning help [Re: 73cuda340] #962258
03/30/11 10:47 PM
03/30/11 10:47 PM
Locomotion Offline
Locomotion  Offline
It is a good idea to check out the carb, make sure everything is clean, adjusted properly and it has the OEM jets and power valve to establish a baseline. You can look it up using the part # - possibly 4777. BUT.....that is the wrong carb for the application! Double pump carbs tend to run on the rich side for higher performance engines. But if there aren't enough cubic inches, converter, gearing, etc. to to get a good vacuum signal, it's not going to behave properly. Holley's can work well OOTB if they are used on a combo close to their designed application. I would bet that it is a lean bog unless the pump cam and squirters are wayyyyy too big. Either way, the carb won't be easy to "bandaid" tune to the heavy truck.
I also suggest a 600-650 vacuum secondary carb.
Re: Holley tuning help [Re: 70Cuda383] #962259
03/31/11 07:30 PM
03/31/11 07:30 PM
clarks summit pa
clarks summit pa
I meant feather it as lightly get on it to get it moving.
Re: Holley tuning help [Re: 73cuda340] #962260
03/31/11 07:32 PM
03/31/11 07:32 PM
clarks summit pa
clarks summit pa
Not sure on jet sizes or size of the squirters or the power valve. I haven't had this apart yet.
Re: Holley tuning help [Re: 73cuda340] #962261
03/31/11 09:08 PM
03/31/11 09:08 PM
Northern Virginia
Moparmaniacc Offline
Northern Virginia
I would try bumping up the timing a little more before messing with the carb.
Re: Holley tuning help [Re: Moparmaniacc] #962262
03/31/11 10:41 PM
03/31/11 10:41 PM
Huber Heights Ohio
greenpigs Offline
greenpigs  Offline
Huber Heights Ohio
Sounds like you need to tear it apart and see what you got first.
69 Charger RT
Re: Holley tuning help [Re: greenpigs] #962263
04/01/11 02:01 PM
04/01/11 02:01 PM
clarks summit pa
clarks summit pa
I adjusted the mixture screws and it is a little bit better now, but the bog is still there and now I have a little hesitation on the top end.
Re: Holley tuning help [Re: 73cuda340] #962264
04/01/11 03:59 PM
04/01/11 03:59 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Go invest in a holley tuning book or 2, i own 3 of them, read em, then read em again. If you know the fuel system is good, the ignition/timing curve is good & no vacuum leaks, THEN look at the carb, most problems are blamed on the carb, because thats the 1st. thing you see when looking at your engine, but most problems are elsewhere.
Re: Holley tuning help [Re: 73cuda340] #962265
04/01/11 07:51 PM
04/01/11 07:51 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
My
First off....for a late model low compression engine with a stock cam in a heavy vehicle... a double pumper and air-gap intake is not the way to go. You want torque to get you off the line. That intake is rated 1500-6500 for a reason. You're hurting off the line torque and wasting fuel with an air gap. Plus ...double pumper carbs are meant to sit on top of a race engine with generally low vaccum signal and lumpy cams. Theyre jetted richer and also idle richer = wasted fuel.
A regular Performer intake (NOT RPM or Air Gap RPM) and vacuum secondary carb is all you need for that setup and will provide more torque at lower rpm. If its a new intake and you can swap it for a performer....do it. Go with a 600 vac sec holley or Edelbrock 625/650 AVS carb and you'll be much happier.
Of course.... theres always a Performer intake and Demonsizzler prepped Thermoquad! Small primaries = Gas mileage and Gobs of low rpm torque + Large vacuum secondaries for when your foot gets happy!
Re: Holley tuning help [Re: Dave440] #962266
04/01/11 08:44 PM
04/01/11 08:44 PM
clarks summit pa
clarks summit pa
I knew before hand that it wasnt the perfect combination for my setup. I only used this carb and intake setup because I already had them laying around as extra parts. Anything is better than the stock 2 barrel setup that was on it as that needed a complete rebuild. It was running so rich that your eyes would burn standing next to it and you could basically watch the gas gauge go down. The truck runs 100 times better than it did. The only problem is if I try to get on it quick it will bog down bad until I get moving. I just want to try to get this fine tuned for now until I get my 340 finished to put in it.
Re: Holley tuning help [Re: Dave440] #962267
04/01/11 09:20 PM
04/01/11 09:20 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
My
Not true.
Re: Holley tuning help [Re: joedust451] #962268
04/02/11 04:43 AM
04/02/11 04:43 AM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
Sounds like a fuel delivery hole from idle to main metering. Even though you said its squirting fuel doesnt mean the pump shot is timed right or its enough. Ive felt cars hesitate...even backfire with fuel delivery holes but they generally dont outright stall like yours.
1. Make sure your float levels are set correctly before you continue to eliminate that as a contributor.
2. Adjust the accel pump circuit timing. On the side of the primary throttle lever check the screw position for the accel pump cam. Its usually in hole 1 from the factory. If so...remove the screw and then move the plastic cam a little so the position 2 hole in the cam lines up with the #2 hole in the throttle lever and screw it down. There may be no threads in the plastic cam #2 hole if its never been used bcus the screw cuts the threads the first time so you should hold the cam in place from behind while tightening the screw. (be careful not to lose the screw as it can fall in the exhaust crossover port...hmmm...how do i know that?)
3. Once the cam is set to #2 position you're going to need to re-adjust the pump lever arm clearance. Make sure to do any curb idle speed adjustments first so its at the desired idle speed. Then with 2 wrenches adjust the accel pump lever to actuator bolt to pump arm contact gap.
If after moving the cam to position 2 theres space between the bolt bottom and accel pump lever then loosen the nut and bolt to make the assy longer until it just contacts the pump lever arm. I go for .005 spacing between the lever and bolt bottom and then loosen the nut just a hair more for nearly zero gap. Theres a little side to side play in the lever arm so if u move it back and forth from underneath it shud just lightly scrape the bottom of the bolt.
If after moving the cam to position 2 its too tight for the .005 feeler gauge...then tighten the nut and bolt together to make the length shorter until you get the .005 gauge between the pump arm and bolt bottom then back the nut off just a hair so so the bolt just scrapes the pump arm.
4. If the stumble is gone you're done. If its mostly gone...go to step 5.
5. Accel pump shooter. If the cam adjustment doesnt help...or not enough... you may need a larger primary shooter. Stock for a 650 DP is probably a 25 or 28. If its a 25 then go to a 28 or 31. Obviously the smallest you can get away with to eliminate stumble will be better for gas mileage and spark plug life. If the stock is a 28...then try a 31. Get the type with extended shooter tubes if possible. I wouldn't recommend trying to drill a stock shooter unless you have set of numbered micro drill bits with precision tolerances and even then....at those sizes you risk breaking a bit...and then ...you have no shooter at all.
The above changes should eliminate the launch stumble.
If not....you may need a different cam profile and might have to buy a Holley plastic cam kit and experiment with different cams.
You really can't go much more on initial timing...but....Since you're already running 14deg initial and 34 total I wouldnt go much more. You risk pinging with todays garbage pump fuel and you dont want to risk piston damage due to pre-ignition. I would at least check the vacuum advance using a hand vacuum pump/gauge tester if you have one or you could try putting a timing light on it and checking the timing with the vacuum advance line removed and the advance port at the carb plugged. Check timing at idle then 1000 1500 2000 rpm. Shut down.... reconnect the vac advance hose and re-test noting advance at same rpm to confirm its advancing. - -
Let us know how you make out.
Re: Holley tuning help [Re: 73cuda340] #962269
04/02/11 04:58 AM
04/02/11 04:58 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the real issue has been pointed out that the air gap intake and double pumper are not a good match for the engine and application. That being said, I think you will have to richen up the transition circuit to cover up the hole between the accelerator pump shot and transition into the main circuit. Usually enlarging the idle restriction and maybe the power valve restriction in the metering plate by a few thousandth should help.
