thanks again Fred. I am about to order a KB block and the options are for larger studs.. I think I can go all the way to 9/16..
The engine will be blown 15lbs , expected peak output 1,100ftlbs & 1,500hp. Not expecting it will see that all the time though.
I am married to the Stage V Replacement heads (and they will support the power), as the chassis has been built around this setup (specifically the headers).
Larger studs seems like a good idea.. just wondering if the heads will fit or if they will need modification or if I should stick with std sizes.
![](/ubbthreads/images/graemlins/beer.gif)
