Line Lock Install #961911
03/29/11 05:52 PM
03/29/11 05:52 PM
Under My Car
Mopar_Country Offline OP
Under My Car
I am getting ready to install my line locks and the installation diagram does not match what I see on the car. The car is a 74 Dart Sport.
Here is the install diagram:
Re: Line Lock Install [Re: Mopar_Country] #961912
03/29/11 05:53 PM
03/29/11 05:53 PM
Under My Car
Under My Car
Here is what I have, I have in red what I think I need to do. Am I close or do I have something figured wrong?
Re: Line Lock Install [Re: Mopar_Country] #961913
03/29/11 07:37 PM
03/29/11 07:37 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
That's how it is on my car.Works fine with no problems.
Nautilus Racing-
Re: Line Lock Install [Re: Chris2581] #961914
03/29/11 07:39 PM
03/29/11 07:39 PM
Under My Car
Under My Car
You have the same type of block? I wasn't sure which line supplied the front, I assumed it was the one that went in the top.
Re: Line Lock Install [Re: Mopar_Country] #961915
03/29/11 07:45 PM
03/29/11 07:45 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'd have to look.All I did was take the line from the front brakes and ran it to the line lock,and a new line from the line lock to the prop valve.
Nautilus Racing-
Re: Line Lock Install [Re: Chris2581] #961916
03/29/11 08:15 PM
03/29/11 08:15 PM
Under My Car
Under My Car
Which reservoir on the MC feeds which set of brakes?
Re: Line Lock Install [Re: Mopar_Country] #961917
03/30/11 05:25 AM
03/30/11 05:25 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
The back one typically feeds the front brakes.
Re: Line Lock Install [Re: Hotwheelsjr] #961918
03/30/11 08:16 AM
03/30/11 08:16 AM
Under My Car
Under My Car
Thanks, I think I'm on the right track. I just want to be sure so I get it right the first time.
Re: Line Lock Install [Re: Mopar_Country] #961919
03/30/11 02:03 PM
03/30/11 02:03 PM
Under My Car
Under My Car
Any other opinions? I'm going forward today or in the morning, so I want to get it right.
Never used one back in the day all we did was back off the rear brakes, LOL.
Re: Line Lock Install [Re: Mopar_Country] #961920
03/30/11 02:22 PM
03/30/11 02:22 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
I think the reason the first diagram is recommended is that when the line lock is activated there is no pressure on either side of the proportioning valve.
The way you are proposing when you take your foot off the brake there will be no pressure on the rear side in the proportioning valve and pressure on the forward side of the proportioning valve.
Might actually be more of a problem in the distribution block as supposedly there is some sort of shuttle valve that can be jammed if there is pressure on one side and not the other, it will think you have a brake failure in one of the lines. At least that is what I have gathered. It seems that a lot of people run it the way you have suggested with no problems though.
Caveat emptor.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Line Lock Install [Re: David_in_St_Croi] #961921
03/30/11 05:06 PM
03/30/11 05:06 PM
Under My Car
Under My Car
In the installation diagram it shows the proportioning valve separate from the distribution block. In my car there is only one solid block on the inside front frame rail. Is it possible the top is the distribution block and the bottom section is the proportioning valve?
Re: Line Lock Install [Re: Mopar_Country] #961922
03/30/11 05:55 PM
03/30/11 05:55 PM
Do you have drums all around? Only disc brake cars have the proportioning valve. I think the installation diagram is correct in that regard. Our 70 RR only has the distribution block, essentially as you describe it, and it is 4 wheel drums.
Re: Line Lock Install [Re: David_in_St_Croi] #961923
03/30/11 06:58 PM
03/30/11 06:58 PM
Under My Car
Under My Car
Drum rear, disc front.
Re: Line Lock Install [Re: Mopar_Country] #961924
03/31/11 07:53 AM
03/31/11 07:53 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mine is also plumbed like Mopar Countrys.Its been in for 5 years and no problems.Mine is bolted in near the master.Rocky
Chrysler Firepower
Re: Line Lock Install [Re: therocks] #961925
03/31/11 09:02 AM
03/31/11 09:02 AM
Under My Car
Under My Car
Thanks Rocky, so you have the same block? It was confusing, the difference between the two. I just don't want to have to do it twice.
Re: Line Lock Install [Re: Mopar_Country] #961926
03/31/11 11:54 AM
03/31/11 11:54 AM
K
Kiddart Offline
Kiddart  Offline
K
Go on the hurst web site go from the master cylinder to distribution block come out from there into the Line lock the T the front brakes. Mine did not work all that well going into the dist block first. and bleed the crap out of the system. when you tink you have it good do it one more time. Mine now works like a charm. I can take my car up to 3000 rpm before it trys to push thru.
Thank you
Kiddart
Re: Line Lock Install [Re: Kiddart] #961927
03/31/11 01:07 PM
03/31/11 01:07 PM
Under My Car
Under My Car
Unfortunately none of those diagrams match what I have in the car. Does your car have the same block I have illustrated above?
Re: Line Lock Install [Re: Mopar_Country] #961928
03/31/11 04:32 PM
03/31/11 04:32 PM
Under My Car
Under My Car
Well, it's in I hope it works.
Re: Line Lock Install [Re: Mopar_Country] #961929
03/31/11 10:46 PM
03/31/11 10:46 PM
K
Kiddart Offline
Kiddart  Offline
K
yes I do the hurst web site calls to put a blocker in the extra port on the valve. if you follow the diagram it works great but blead the crap out of it
Thank you
Kiddart
Re: Line Lock Install [Re: Mopar_Country] #961930
04/01/11 07:50 AM
04/01/11 07:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mopar mine is just like that.Mine bled right out no problems.I can lock the discs and let the clutch out and light up the 12 inchers on the rear.Rocky
Chrysler Firepower
