Page 3 of 6 1 2 3 4 5 6
Re: 46RE standalone controller (I think I'll design one) [Re: hooziewhatsit] #961887
04/24/12 01:12 AM
04/24/12 01:12 AM
hooziewhatsit Offline OP
Ok. I pulled the solenoids/sensors out of my core 46RE earlier tonight so I can mess around with them.
Later I'll order the $50 harness from flebay so I can hook up to it easier.
Slowly moving forward
Re: 46RE standalone controller (I think I'll design one) [Re: hooziewhatsit] #961888
05/08/12 01:52 PM
05/08/12 01:52 PM
GA
roadrunninMark Offline
GA
you have an update on your progress, Hoozie?
Re: 46RE standalone controller (I think I'll design one) [Re: roadrunninMark] #961889
05/08/12 07:49 PM
05/08/12 07:49 PM
Sadly, nothing new yet. Too many other projects at the moment, and one of my clients just added another
Then throw in caring for 5 orphaned kittens, and my parents deciding to visit this week
Re: 46RE standalone controller (I think I'll design one) [Re: hooziewhatsit] #961890
01/08/13 01:49 PM
01/08/13 01:49 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
BTT!!!
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: 46RE standalone controller (I think I'll design one) [Re: BBR] #961891
01/09/13 01:24 PM
01/09/13 01:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You mention they are gonna be for older cars, well how is the speedometer gonna work? There is no gears on the out put shaft and no hole in the output shaft housing for the speedometer gear
Re: 46RE standalone controller (I think I'll design one) [Re: HotRodDave] #961892
01/09/13 03:17 PM
01/09/13 03:17 PM
There's another guy online that sells a box that takes an electronic speed signal, then drives a stepper motor to spin the speedometer cable.
We'd have to get that, or I may end up building one of those as well.
Re: 46RE standalone controller (I think I'll design one) [Re: hooziewhatsit] #961893
01/09/13 06:19 PM
01/09/13 06:19 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
This is a product that the Durango/Dakota/Jeep guys would love to have. 42/44/46RE's
It would be so nice to use a different ECM like a Megasquirt without having to piggyback on the stock JTEC and hoping you don't do something to kick it into limp mode. Or even ditch the EFI all together and use a carb if you want.
I searched the megashift forum and never found where anyone had really made any progress adapting it to a Mopar trans.
RMRW 2018
RMRW 2020
Re: 46RE standalone controller (I think I'll design one) [Re: hooziewhatsit] #961894
01/09/13 06:20 PM
01/09/13 06:20 PM
OHIO
BUBBAZ572 Offline
MR. CAPS LOCK
BUBBAZ572  Offline
MR. CAPS LOCK
OHIO
DAKOTA DIGITAL HAS A OUTPUT SENSOR GPS-50-1
WORKED GREAT FOR ME
Re: 46RE standalone controller (I think I'll design one) [Re: HotRodDave] #961895
01/09/13 06:37 PM
01/09/13 06:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Only the '98 and later are lacking the speedo drive in the tail. The output shaft speed sensor could be used to provide an electic speedo input.
Re: 46RE standalone controller (I think I'll design one) [Re: BBR] #961896
01/09/13 07:25 PM
01/09/13 07:25 PM
That was kinda the idea. For myself, I'm looking at doing the Ford 5.0 EFI, and would need either this controller, or an RH transmission.
Last I checked, one guy had made the megasquirt trans controller work with an RE, but you have to find the right circuit boards and the right code, and then make it work. I'm aiming for an OOTB solution.
My controller will need to know the vehicle speed, so it will either need to:
A - use a speedometer cable pass through that generates an electronic signal that goes to the controller (like this http://www.summitracing.com/parts/SUM-G2887-1/)
or B - Use the electronic speed signal from the trans, and then drive a stepper motor to work with cable driven speedometers.
Re: 46RE standalone controller (I think I'll design one) [Re: hooziewhatsit] #961897
01/10/13 12:56 AM
01/10/13 12:56 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
AutoMeter sells a speed sensor/speedo drive for about $80
Re: 46RE standalone controller (I think I'll design one) [Re: BulletBob] #961898
01/10/13 02:39 AM
01/10/13 02:39 AM
Do you have a link or part number?
Re: 46RE standalone controller (I think I'll design one) [Re: hooziewhatsit] #961899
01/10/13 02:46 AM
01/10/13 02:46 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
FWIW....I use a Cable X speedometer adapter, and it works well for me.
(On my LS1/T56 swap into the Torana with mechanical speedo)
Re: 46RE standalone controller (I think I'll design one) [Re: OzHemi] #961900
01/10/13 02:26 PM
01/10/13 02:26 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Linking trans control efforts...
http://www.racemagnum.com/showthread.php?p=939511#poststop
Might have to be a member to read though.
RMRW 2018
RMRW 2020
Re: 46RE standalone controller (I think I'll design one) [Re: BBR] #961901
01/12/13 10:54 PM
01/12/13 10:54 PM
Ok transmission experts...
If I built a test rig with the engine/trans outside of a vehicle, would I need to put the transmission under load to properly test everything (governor pressure, etc)?
Or could I get away with just running it and taking my measurements?
Re: 46RE standalone controller (I think I'll design one) [Re: hooziewhatsit] #961902
01/13/13 04:39 PM
01/13/13 04:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You would need to manipulate the throttle valve in relation to an imagined "load" to test it but it sounds like you just need to manipulate the gov. press. strictly in relationship to the output shaft RPM. For simplicity you could ignore the temp and just make the pressure go up in relation to RPM.
Another thought I had about this the other day was while watching them on the datastream on my scanner shows them to jump up or down in big steps rather than smooth rise and fall like the computer is trying to command an exact shift time rather than a smooth rise and fall where the trans just shifts but I would expect it to work just fine with gradual rise and fall in relation to RPM.
Re: 46RE standalone controller (I think I'll design one) [Re: HotRodDave] #961903
01/14/13 11:47 AM
01/14/13 11:47 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
One thing to probably remember is the stock calibration would probably be geared more towards smooth soccer-mom friendly shifts. We as gearheads are typically more interested in solid quick gear changes.
RMRW 2018
RMRW 2020
Re: 46RE standalone controller (I think I'll design one) [Re: BBR] #961904
01/14/13 06:07 PM
01/14/13 06:07 PM
GA
GA
the mad scientist has returned...
Re: 46RE standalone controller (I think I'll design one) [Re: roadrunninMark] #961905
01/30/13 01:34 PM
01/30/13 01:34 PM
GA
GA
Any updates from the lab?
Re: 46RE standalone controller (I think I'll design one) [Re: roadrunninMark] #961906
04/07/13 05:51 PM
04/07/13 05:51 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Soooooooo……can I order a controler yet?
