Re: motor guru help needed
[Re: TrueTripleX]
#961719
03/29/11 02:58 PM
03/29/11 02:58 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
My son-in-law had a lifter stick on his motor. worn lobe, 3 bent valves. He had the heads re-done and put a new cam and lifters in the block and now has a new problem. Passenger side bank has all holes showing 75-80 on compression. Driver side is all 120-125. Needless to say, the car runs horrible. What is wrong with this?
Did this include a full tear down and cleaning of the engine ? That lobe material is distributed throughout the engine. What did the piston skirts below that lobe look like ?
[Re: drew72]
#961722
03/29/11 05:55 PM
03/29/11 05:55 PM
Posts: 549 Oregon
abodyman
super street
super street
How does the engine run? Does it miss and stumble? Try warming it up, then do a compression test. Usually we take out all the spark plugs first, then disconnect the fuel line, open the carb all the way and test. Watching the comp.gauge needle, take a reading after the needle jumps twice...say as in it jumps up to 75 lbs, and then You turn the motor a little, more and then jumps to 100 lbs...NOT by cranking for 5 minutes and then taking a reading! You can also squirt a little oil into each plug hole, to perhaps see, if the rings can be worn out..usually You will get a higher reading doing this. Did You flush out the motor, or change the oil and filter at least? Now is when You should cut apart the oil filter and see, if You can find any metal particles in the filter. Thats a real eye opener!
[Re: TrueTripleX]
#961724
04/01/11 04:36 PM
04/01/11 04:36 PM
JohnRR
There was NO tear down of the motor. We have NON adjustable push rods and there was NO damage to the top of the pistons. I just don't understand why one entire bank of pistons is carrying 75 lbs and the other complete side is carrying 125 lbs compression.
The tops of the pistons won't show the damage that gets done to the SIDE of the piston BELOW the rings and the damage it does tot he cylinder walls , but it should be a whole bank for one lobe .
Squirt a little oil in all the cylinders and see what you get .
[Re: JohnRR]
#961725
04/01/11 04:55 PM
04/01/11 04:55 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
were the heads shaved in the rebuild?
I am truckless..
