Fabricated Aluminum Valve cover baffles? #961187
03/28/11 08:08 PM
03/28/11 08:08 PM
Nevada
theman440 Offline OP
Nevada
Anybody runnin' fabbed aluminum covers without baffles? Wondering if needed to keep oil splash off of breather and/or PCV.
Re: Fabricated Aluminum Valve cover baffles? [Re: theman440] #961188
03/28/11 08:17 PM
03/28/11 08:17 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Yes, but used these instead of fabbing up a baffle internaly.
Re: Fabricated Aluminum Valve cover baffles? [Re: Todd] #961189
03/28/11 08:22 PM
03/28/11 08:22 PM
Ohio
Todd Offline
Todd  Offline
Ohio
What it looks like installed.
Re: Fabricated Aluminum Valve cover baffles? [Re: Todd] #961190
03/29/11 12:32 AM
03/29/11 12:32 AM
Nevada
Nevada
Where can I get them ?
Re: Fabricated Aluminum Valve cover baffles? [Re: Todd] #961191
03/29/11 12:39 AM
03/29/11 12:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
And that is installed above the WIDE rocker shaft mount,
am I correct... I look at that point but I prefer
the front one... but I also prefer a baffle........ JMO
Re: Fabricated Aluminum Valve cover baffles? [Re: theman440] #961192
03/29/11 07:39 AM
03/29/11 07:39 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Got them at summit racing. Yes Raff they are installed above the rocker shaft mount bolt. Just got it running the other day for the first time and seem to be working so far.
Re: Fabricated Aluminum Valve cover baffles? [Re: Todd] #961193
03/29/11 03:54 PM
03/29/11 03:54 PM
Nevada
Nevada
Did your breathers push right in or did you modify them ?
Re: Fabricated Aluminum Valve cover baffles? [Re: theman440] #961194
03/29/11 04:09 PM
03/29/11 04:09 PM
Ohio
Todd Offline
Todd  Offline
Ohio
pushed right in and fit nice and tight.
