Performance Racing Warehouse Roller Rockers #961153
03/28/11 07:19 PM
03/28/11 07:19 PM
Ohio United States
Bones 08 Offline OP
Bones 08  Offline OP
Ohio United States
Has anyone used or know anything about PRW's Rocker Arms? Aluminum or Stainless. Thinking about purchasing for a 416 stroker with edelbrock LA heads.
Re: Performance Racing Warehouse Roller Rockers [Re: Bones 08] #961154
03/28/11 08:00 PM
03/28/11 08:00 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I would shy away from the aluminum. If I where going to try a set it would be the bushed stainless.
Re: Performance Racing Warehouse Roller Rockers [Re: Bones 08] #961155
03/28/11 08:20 PM
03/28/11 08:20 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
I have a set of the aluminums on my new 500 wedge with Eddy heads. They look good and went on with out any problems. The engine hasn’t been run yet, but very soon. I’m still finishing up the car. The shop I bought them from says he has several sets running here East TN with out any problems. Guess I’ll find out.
Re: Performance Racing Warehouse Roller Rockers [Re: Bones 08] #961156
03/28/11 08:35 PM
03/28/11 08:35 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
They arent a bad price for the money. but clearly not a Comp Pro Magnum.Change out the supplied bolts however.
RIP Monte Smith
Re: Performance Racing Warehouse Roller Rockers [Re: CompWedgeEngines] #961157
03/28/11 11:20 PM
03/28/11 11:20 PM
PA
W
w7smallblock Offline
W
PA
I just bought a set of the stainless for a budget 408. They seem like nice pieces for the price a got mine on ebag for $281 shipped to my door. I was told to stay away from the aluminum ones was told they have cheap bearings that will cause problems with much above a stout hydralic or decent solid spring. Ryan J has them the stainless on his big block street car and told me he lashed the valve's when motor was new then after 9,000 miles and lash was only .003 diff. seems good to me.
Re: Performance Racing Warehouse Roller Rockers [Re: w7smallblock] #961158
03/29/11 07:05 AM
03/29/11 07:05 AM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
I believe had i not already took delivery of my hughes rockers i would be considering a set of these in stainless, whatta ya think ED??
Re: Performance Racing Warehouse Roller Rockers [Re: Lew] #961159
03/29/11 12:01 PM
03/29/11 12:01 PM
NC
Badfish67 Offline
Badfish67  Offline
NC
Ryan put a set of the stainless rockers on my small block nitrous motor and they have been great so far. I keep checking the lash, but its always been good.
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: Performance Racing Warehouse Roller Rockers [Re: Badfish67] #961160
04/13/11 07:36 PM
04/13/11 07:36 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
Ryan j is shady dell?
74 dart sport 440 www.Csucarbs.com
Re: Performance Racing Warehouse Roller Rockers [Re: shoebox] #961161
04/13/11 07:55 PM
04/13/11 07:55 PM
Get-X Offline
Get-X  Offline
Yes, Shady Dell Speed Shop.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Performance Racing Warehouse Roller Rockers [Re: Get-X] #961162
04/15/11 12:33 PM
04/15/11 12:33 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
does ryan change out any of the hardware or adjusters?
Re: Performance Racing Warehouse Roller Rockers [Re: shoebox] #961163
04/15/11 01:23 PM
04/15/11 01:23 PM
NC
Badfish67 Offline
Badfish67  Offline
NC
Yes, we did use the T&D adjusters. All the other parts are fine.
Re: Performance Racing Warehouse Roller Rockers [Re: Badfish67] #961164
04/15/11 03:42 PM
04/15/11 03:42 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Its not been brought up yet, but even for a mild roller the prw-s are what I consider the poor mans HS, as mentioned swap out the adjusters.
But what has not been mentioned here is although the T bearing used in the prw-s have if I recall 4 less rollers in there T style needle bearing ITS a direct cross ref part number to the same bearings used in the HS rockers.
So there then the possible quality of the al used and the fact they are not as wide, here again I see them as the HS on the cheap and do know of several sets in use with no problems in the 550-600 open area, NOT in the 700-750 area.
http://www.wholesalebearing.com/nrcagetype.html
HS has the INA SCE 146, PRW IKO BA 146 Same specs, interchangable if needed.
Re: Performance Racing Warehouse Roller Rockers [Re: quick77rt ] #961165
04/15/11 04:50 PM
04/15/11 04:50 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
Very interesting
