Hemi heat riser counterweight #960862
03/28/11 11:11 AM
03/28/11 11:11 AM
PA
BS27ROB Offline OP
BS27ROB  Offline OP
PA
Does anyone have a picture of the backside of an original hemi heat riser counterweight. I'm installing a reproduction and the tab circled in red seem like it's going to catch on the anti-rattle spring. What am I doing wrong? Has anyone else had a problem?
Thanks Cy
Re: Hemi heat riser counterweight [Re: BS27ROB] #960863
03/28/11 11:43 AM
03/28/11 11:43 AM
Cleveland, OH
TWS Offline
TWS  Offline
Cleveland, OH
Re: Hemi heat riser counterweight [Re: TWS] #960864
03/28/11 05:50 PM
03/28/11 05:50 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Pretty sure that part is where the asbestos sleeve goes to keep it from rattling against the post.
Re: Hemi heat riser counterweight [Re: 68jim] #960865
03/28/11 07:14 PM
03/28/11 07:14 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Yes it does
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: Hemi heat riser counterweight [Re: MMC Detroit] #960866
03/29/11 12:15 AM
03/29/11 12:15 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
One more thing about those hemi heat riser counterweights - Do yourself a very big favor and put a small tack-weld between the weight and shaft. After getting all my pieces in place and clamped down "tight" with the little bolt, it vibrated loose on one of the early test drives and was never recovered...and I spent a lot of time trying to find it. Of course you just can't purchase the counterweight by itself, you have to get the whole kit ($$$$) So this time I got everything in place again - tight - and broke out the welder to insure there would be no repeats of the problem. Just a small tack-weld does the trick and is easily reversible if I need to remove the counterweight in the future.
My
Re: Hemi heat riser counterweight [Re: 68jim] #960867
03/29/11 06:02 AM
03/29/11 06:02 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
My
What about a little high-heat locktite? Would seem a little easier to me.
