Hey Guys,
I know this is very basic stuff .. but wanted to run past the experts here to see if I'm overlooking anything. This will be the first time I'm attempting to remove my six-pack carbs (I need to fix a leaky Accelerator Pump on the Center carb), so wanted to make sure I am doing this right.
On the Passenger side, I will first need to disconnect all the vacuum lines and PCV hoses. For the Choke assembly, I was going to try to un-hook it right at the Choke clip (and leave the thin vertical rod that comes up from the manifold in place - is this correct?).
For the Fuel lines, it looks like I need to disconnect all 3 at the carbs and at least loosen up the outboard carb's line at the fuel line connector (see arrow) - so that I can move it to get to the center carb's rear pass-side bolt.
And on the Driver's side, looks like I just need to disconnect the throttle linkage and throttle return spring there.
Then, just un-bolt the front carb, and then the center carb.
Does this sound all correct or are there steps I'm overlooking here?
To put back on after fixing accelerator pump or rebuilding center, I'll just need to slap on some new carb-to-manifold gaskets and do everything in reverse, correct?
Thanks all for help and advice as always!
