PS coupler housing free play
#96032
07/28/08 01:05 PM
07/28/08 01:05 PM
How much free play should there be between the H blocks and the housing? I looked at putting in a rebuild kit but I saw the old H blocks were tore up pretty bad.
the new blocks have a slight amount of side to side play.
Any idea of a part number for the housing (or where to get one?)
Re: PS coupler housing free play
#96033
07/30/08 11:01 AM
07/30/08 11:01 AM
I guess no one has ever had to buy a new housing? I was looking to replace mine- its all scored up inside
#96036
07/30/08 12:19 PM
07/30/08 12:19 PM
Posts: 2,836 Detroit boy in Saugerties, NY
BrianShaughnessy
Bouchillon sells new repros. Not cheap.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana. Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart. El Grande: '98 Grand Cherokee 5.9 Limited.
[Re: BrianShaughnessy]
#96037
07/30/08 12:38 PM
07/30/08 12:38 PM
ya, I just found those while searching around. they want $112
I ended up getting a used one from firm feel. $25! (i hope it is good!)
[Re: IronWolf]
#96039
07/30/08 01:23 PM
07/30/08 01:23 PM
i have the rebuild kit and thats how I first noticed the problem. when i took the H blocks out, they were all scored and scratched on the thrust side. the housing had similar marks. I dont want to put the new kit into the bad housing cause it will just ruin those blocks too.
[Re: IronWolf]
#96040
07/30/08 07:19 PM
07/30/08 07:19 PM
Posts: 6,516 Santa Cruz, California
Lefty
Also, I believe "Flaming River" sells couplers (which may require some fitting or cutting), which eleinates the somewhat sloppy stock arrangement.
![](http://members.cruzio.com/~dane/66%20Coronet/Steering%20Upgrades/DSCN1803.JPG)
[Re: Lefty]
#96041
07/30/08 08:07 PM
07/30/08 08:07 PM
Posts: 5,337 the house on the left.
cogen80
i like that flaming river piece way better then the stock thing.
[Re: cogen80]
#96042
07/31/08 07:58 AM
07/31/08 07:58 AM
its almost $200 too. ![](/ubbthreads/images/graemlins/eeek.gif)
the problem I have with it is that it seems to remove the slidein action between the coulmn and the box. so theres no way to handle changes in the distance between the box and the column caused by the body flexing because of bumps or just because of alignment issues. I think that could eventually take its toll on the steering shaft or the PS gear box
[Re: cogen80]
#96043
07/31/08 09:37 AM
07/31/08 09:37 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
I really like that piece as well and would like to swap mine out but it dosen't look like they have one for an original manual steering car.
#96044
07/31/08 09:39 AM
07/31/08 09:39 AM
GTXKen
super gas
super gas
I would think that if you have added torque boxes or frame connectors you have eliminated the body twist that makes the play in the stock unit necessary
Ken
[Re: buildanother]
#96046
07/31/08 05:17 PM
07/31/08 05:17 PM
Lefty
The flaming river piece looks like it mounts solid on both ends, leaving no free area to allow for firewall flex etc. Sooner or later may cause a problem with probably steering column.
I disagree; I don't feel any vibrations through the shaft to the steering wheel. If there were lots of movement, the factory hard brake lines from the firewall master cylinder to the frame mounted dist block would crack. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Lefty]
#96047
08/01/08 12:04 AM
08/01/08 12:04 AM
those metal brake lines are somewhat flexable (notice the little curly q's on them??) and they are close to the firewall. as you move away, the flexing get larger (moment arm) and that could break those delicate plastic retainers that are in the steering column that allow it to collapse in an accident- maybe
#96048
08/01/08 12:22 AM
08/01/08 12:22 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Removing the stock coupler and simply adding the Flaming River coupler in your picture is not a complete solution. The two parts do not share all the same functionality. The original part allowed for slight compresion and expansion which adresses the issue you are talking about. The Flaming River part functions exactly as it is intended to, but it was never designed to allow for compression and expansion of the joint. Flaming River does sell components that allow for that functionality, but you are not incorporating them into this swap when you are using just their coupler joint.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
#96051
09/02/08 11:54 PM
09/02/08 11:54 PM
Posts: 515 Dayton, Ohio
65cuda
mopar addict
mopar addict
Dayton, Ohio
i never had any trouble with them being dry. every one i have taken apart was lubed. they just get loose. too much play. i bought that boot thing at a show too. split in half when i tried to put it in. that was 15.00 wasted. the one on my Duster hits my headers when i turn the wheel. i just want something smaller that will last longer. so i have the flaming river one on the way. i will give it a try. if it works i will buy one for my cuda too. somebody must be using them. ![](/ubbthreads/images/graemlins/hammer.gif)
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
