Re: Supercharged 400 question
[Re: DaytonaTurbo]
#959020
03/30/11 08:14 AM
03/30/11 08:14 AM
Posts: 26 atlanta
dvanecek
atlanta
Any thoughts on Racer Brown Cams? I spoke with Jim and for around $165 I can get a custom ground cams. I heard nothing but good things about him. That seems like a pretty place to spend a little money to get it right.
Another question what size carb? I have Holley 750 DB on my 383. I realize that I will have to convert to for blow through application, but I'm wondering a 750 is enough.
[Re: dvanecek]
#959025
04/13/11 10:44 PM
04/13/11 10:44 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Keep in mind that the better the heads flow, the less boost you'll be able to produce. With that in mind, I don't think 500 hp is out of the question at all. The 750 will flow considerably more when you add more than atmospheric pressure to it. I would consider sending that carb off to Competition Carburetion. http://www.competitioncarburetion.com/index.htmTell him your combo and he'll work some magic.
[Re: dodgeboy11]
#959026
04/13/11 11:50 PM
04/13/11 11:50 PM
Posts: 7,664 IN
ahy
IN
Keep in mind that the better the heads flow, the less boost you'll be able to produce. With that in mind, I don't think 500 hp is out of the question at all. The 750 will flow considerably more when you add more than atmospheric pressure to it. I would consider sending that carb off to Competition Carburetion. http://www.competitioncarburetion.com/index.htm Tell him your combo and he'll work some magic.
I'll guess 300 NA and 500 with boost. With a stock rebuild (cast pistons?) 10-12 lb boost is a lot. Agree as posted above with help from better flowing heads you won't need 10-12 lb boost to get 500 HP. I just wouldn't try to push it above 500 HP with a stock style rebuilt short block. During the tuning process any lean condition and/or detonation will kill the pistons. Careful and good luck!
[Re: ahy]
#959027
04/14/11 12:00 AM
04/14/11 12:00 AM
Posts: 26 atlanta
dvanecek
atlanta
Yep that's why I'm starting with a rebuilt shortblock that I got from craigslist for $350 bucks
Any more guess?
[Re: dvanecek]
#959029
04/15/11 12:14 AM
04/15/11 12:14 AM
Posts: 350 Grande Prairie, Alberta, Can.
CW25
OK so I decided to pull the trigger on a set of 440 source stealth heads. Anyone wanna guess what a stock rebuilt 400 with edelbrock rpm intake, stealth heads, custom ground cam, 8-10 lbs of boost would put out for hp and torque? I know a stock 400 what pretty low on HP but decent for torque. the headers, intake, cam and heads gotta help, so with the boost I'm guessing I should be over 500/500.
Am I off base?
Look at my sig. I run a .035" over 400 stock stroke 9:1 compression, untouched stealth heads and a small hyd roller cam. 224*/230* with only 26* timing and a peak boost of 8 psi in a 4000+ lb truck. Put that power in a 3300 lb car and get it to lauch better than my 1.88 60 foot and it is a easy 10 second car. Put a cage in it. LOL This is also with a properly sized boosting device.
[Re: CW25]
#959030
04/15/11 08:44 AM
04/15/11 08:44 AM
Posts: 26 atlanta
dvanecek
atlanta
That truck is awesome. This is going in a '47 dodge business coupe. Should be about 3600 lbs. This should be a fun torque monster. I'm getting my 727 rebuilt next week. upgrades bands/clutches and a 4 pinion planet.
So quick question about Stealth heads. I have heard that it's a good idea to replace the locks on these heads. Can I swap in Comp cams 7* locks or should I do locks and retainers. Anything else I should check on these besides a smooth gasket surface and the locks?
