Re: Easy Six-Pack Throttle Linkage Question
[Re: stan1970]
#95811
07/27/08 11:55 PM
07/27/08 11:55 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Sometimes the throttle blades on the outboards can stick shut. This was an issue with the early models, but can happen to any of them when they are left shut for a long time. Corrosion etc can cause them to stick and bind.
As the previous post points out, with the car not running- open the center carb all the way, now try opening the outboard cabs by moving the outboard linkage/tabs to their wide-open position. All 3 carbs should open smoothly and without sticking or binding. When the center carb is closed, it's linkage will shut the outboards too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
