360 Rocker/Push rod Question #957972
03/24/11 08:25 PM
03/24/11 08:25 PM
Orangeville, Ontario, Canada
Red Express Offline OP
Ok,
Bought a set of comp rockers that accept a ball/ball pushrod... 360sb
Not sure if my OEM push rods are the right length... but... here is the question..
I think my OEM push rods are 9/32 dia and the rocker install sheet says to use 5/16 dia...
Will that 1/32nd of an inch make any difference?
Like I said I don't if the length will work anyway.. just curious what you guys thought.
I should say this is a street car that might do to the track once a year... .490 lift hydraulic cam.
Thanks..
Darcy & Allan MacCoubrey Worlds Fastest Lil Red Express Truck 10.48 @ 128 mph [url] www.raceosca.com [/url].
Re: 360 Rocker/Push rod Question [Re: Red Express] #957973
03/24/11 09:17 PM
03/24/11 09:17 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If they are adjustable rockers they will not be usable with the standard length push rod. The adjust extends down through the rocker to far. With standard heads or heads with minimal milling a set of push rods from Summit for use with hydralic lifters with adjustable rockers should work just fine. There is a lot of forgiveness in the hydraulic lifter.
Re: 360 Rocker/Push rod Question [Re: Red Express] #957974
03/25/11 12:15 AM
03/25/11 12:15 AM
Yes the ball dia must match the cup dia (if that is what you are asking)
Re: 360 Rocker/Push rod Question [Re: RapidRobert] #957975
03/25/11 09:16 AM
03/25/11 09:16 AM
Do the lifters have a cup that needs to be matched or will any push rod work in the lifter?
I pretty much thought the push rods would be short but didn't know for sure... I'll mount them this weekend and mock it up for length.
Re: 360 Rocker/Push rod Question [Re: Red Express] #957976
03/25/11 10:17 AM
03/25/11 10:17 AM
Upper Midwest
Upper Midwest
They pretty well work with what you have as long as there isn't and extreme difference.
