There appears to be a way, in the wiring diagram, that the points disti will work with the MSD 6, but I was referring to using the electronic distributor which came with the kit...
I had planned to upgrade the car from points to electronic...but that was before I found the variable timing module. After I found that, I figured to put that in too.
I thought I saw in the diagram a method of hooking directly up to the electronic distributor...but are you saying that it can't be done that way?
I thought I also saw an instruction which said not to hook up the vacuum assist on the disti...now does that make any sense?
