Page 2 of 4 1 2 3 4
Re: 650 hp in a street car. [Re: mickm] #956901
03/24/11 12:06 AM
03/24/11 12:06 AM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I've got a 528 Hemi backed by a 4 speed and a 3.54 dana. With a relatively mild hydraulic roller cam I'm running, it makes great power and is as tame as a 440 to drive on the street until you unleash the beast.
Re: 650 hp in a street car. [Re: Paul_B] #956902
03/24/11 12:24 AM
03/24/11 12:24 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
415 RWHP chassis-dyno here. I need more power. Big Block old schools have something that modern small blocks will never have.
Panache.
Re: 650 hp in a street car. [Re: 73cuda340] #956903
03/24/11 12:51 AM
03/24/11 12:51 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I would not put a HP number on it because alot depends on how the engine and car are built.
Just need to be more attentive to your driving with all that power. The extra power can make you think your driving a smaller/lighter car, and you can exceed the speed limit very easy if you don't check the speedometer. The reality is that on the street there are very few times and/or places where you can even use more than 1/2 throttle. Some places you may try using full throttle, like merging onto a highway or passing a car, you still need to be careful with loss of traction, and running up on slower traffic at triple digit speeds.
Re: 650 hp in a street car. [Re: feets] #956904
03/24/11 05:50 AM
03/24/11 05:50 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
You haven't driven the correct turbo car.
I use to get that all the time with the Reliant and Daytonas I owned Feets, people always ask "why do you waste your time with those things?"
Then they go for a ride or better yet slide behind the wheel... Like getting a wake up call from God as he slams you from behind with an 18 wheel'er.
BTW- The Reliant (135 cubic inches) was dyno'd at over 440hp to the wheels and whould just light the tires up at 80 mph when you roll into the throttle. The driver of the "chase car" when on road tests would recount how he would see the car just skirt sideways and leave yards of black rubber on RT85 when working on the calibration.
Boost is good.
Re: 650 hp in a street car. [Re: gdonovan] #956905
03/24/11 08:23 AM
03/24/11 08:23 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Been driving lots of different +600hp street cars for years, and the ticket to having an engine like that and still enjoy it on the street is, TORQUE!..or overdrive which is the route I went on my last hotrod. Build the car with milder gears so its not anoying to drive, and build a motor that idles with what your willing to live with and makes lots of torque and will peak where you want to shift it, not neccessarily where the heads peak like a race motor. Hemis have always been king for moving big heavy cars...Just look at all the SS ones, wedges are in the 10's, hemis are in the 9's...
Personally, I hate wedge motors. I could care less if I ever worked on one again. I like having skin on my hands after pulling plugs after a run...So for me, it would be a stroked Hemi, small block or big block..They are very potent.
The enjoyment comes from reliability in the valve train, and the street manners of the car. One note though, an 8-3/4 will not live more than the first full throttle hit with a set of drag radials and +600hp.. We broke 4 of them last year in our Hemi Charger street car on drag radials...And a host of other parts. When you make big power, stock parts don't live long, and torque will always find the week link.
Re: 650 hp in a street car. [Re: 73cuda340] #956906
03/24/11 01:23 PM
03/24/11 01:23 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
My thoughts are:
1. sounds good to me
2. do it to it
3. have fun
I'm making 499.75 at the wheels here with a homebuilt
451 Wedge, it's a fun street car and more power would be better! I just fill it up with 93 and head down the road
My car is pretty tame and very simple compared to alot of the guys I associate with, or run into regularly
Around here it is not uncommon to find a high compression, aluminum rod, multiple carb V8 car putzing around Woodward on a Saturday like it's no big deal. Or a roots blown deal. Or an EFI forced induction rig. Or a nitrous rig....and so on. You name it, they can all make the power and then some. 650 is not a lofty goal for a hemi, you won't have a problem as long as common sense is applied.
You can't possibly ever have too much power
you CAN have a chassis, driveline, tires, or driver that is not able to handle it though...which you will probably want to address...in your own personalized way, in your own time....
After reading you will probably need a stronger axle 18 times or whatever it has been, I'm sure the point has been made so I'm not going to repeat it
So I say do it and enjoy yourself....
You didn't ask "how" to do it, or "what else will I need", which everyone is trying to answer their way is great and the best, etc etc....that's a discussion I won't be part of.
I say "do it your way".
How do you want to accomplish it?
Rich H.
Esse Quam Videri
Re: 650 hp in a street car. [Re: Darryls-Demon] #956907
03/24/11 02:45 PM
03/24/11 02:45 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My .030 over 440 makes 643HP at 6300RPMs and 592lbs of torque at 4400RPMs.
Can I see the details of your combination? And do you have any ET & MPH results from track to go along with it? Thanks!
Re: 650 hp in a street car. [Re: 73cuda340] #956908
03/24/11 02:54 PM
03/24/11 02:54 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
My thoughts... just do it, life is too short
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 650 hp in a street car. [Re: jbc426] #956909
03/24/11 04:33 PM
03/24/11 04:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Part of the fun includes seeing the general public's reaction to an old school, high compression big block with a lopy idle, especially when the exhaust cutouts are open...
There's no way to fake that with a smooth idling turbo...
Here's that ancient video of the hot rod idling. It's enough to turn heads when I pull in to the local cruise spot.
http://www.youtube.com/v/9QMuJ6Ngmfs
- Stu Harmon
Re: 650 hp in a street car. [Re: feets] #956910
03/24/11 04:59 PM
03/24/11 04:59 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Hey, that would turn my head too. Sounds sweet Feets, especially with the whistling noise. You don't hear them like that too often.
Re: 650 hp in a street car. [Re: BradH] #956911
03/24/11 05:13 PM
03/24/11 05:13 PM
Re: 650 hp in a street car. [Re: jbc426] #956912
03/24/11 05:35 PM
03/24/11 05:35 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I think you're fine driving a 650 HP engine on the street, depending on who dynoed the engine
2 kids and a dog
Re: 650 hp in a street car. [Re: 73cuda340] #956913
03/24/11 05:44 PM
03/24/11 05:44 PM
BradH Offline
BradH  Offline
Forget about the HP, but my car runs mid 10s in full street trim. And so I'll add that...
- my wife is scared of the car after driving it around in a parking lot... and that was before I swapped the power steering for manual
- one of my best friends is scared of the car after I let him make a pass at the track in it... and he backed off and only ran in the 12s
- the tires are "spin happy" if you don't watch the throttle... the whole CAR is "spin happy" when the roads aren't dry
- it's not tiring to drive, other than the 3" exhaust is kind of loud and there's no AC for the summer heat & humidity
Big-block E bodies are simply not balanced driving machines, unless you strap 'em down w/ anti-roll bars front & back, stiff shocks, etc. And then they don't hook worth a crap at the track, because they need the weight transfer to keep from just sitting there and spinning the tires off the rims.
Re: 650 hp in a street car. [Re: BradH] #956914
03/24/11 08:20 PM
03/24/11 08:20 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
What are the specs on the motor and car?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 650 hp in a street car. [Re: 73cuda340] #956915
03/24/11 08:57 PM
03/24/11 08:57 PM
How about over 750hp in a street car?
Re: 650 hp in a street car. [Re: Dragula] #956916
03/24/11 09:06 PM
03/24/11 09:06 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Re: 650 hp in a street car. [Re: feets] #956917
03/24/11 09:22 PM
03/24/11 09:22 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
I dont know,it sounds alot like my 7.3 powerstroke.
Re: 650 hp in a street car. [Re: 70RT Charger] #956918
03/24/11 09:33 PM
03/24/11 09:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: 650 hp in a street car. [Re: BradH] #956919
03/24/11 11:15 PM
03/24/11 11:15 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Sure here is the combo.
.030 over 440
bushed lifter bores
11.1 CR
Comp solid roller cam [Email]248-254@.050[/Email], .622-.612 with 1.6 rockers
all the bearings coated.
MW ported SR heads
Ported indy DP intake, Pro-Systems carb
Lots of engine coatings- inside and out outside of the intake,tops of the pistons, sides of pistons, intake ports exhaust ports.
Do all those coating help make HP? who knows, the motor does rev quick thow.
Bud Yancer did the machine work and Sheldon Gecker bolted it together.
No I have not had it to the track, as I said it keeps throwing the alternator belts. I need to come up with some kind of idler pulley for the belts.
Also the pistons are five out of the hole with a .039 head gasket.
Re: 650 hp in a street car. [Re: Darryls-Demon] #956920
03/25/11 11:07 AM
03/25/11 11:07 AM
BradH Offline
BradH  Offline
Interesting... It would be nice to know how much of that really translates to on-track performance, since dynos can vary so much.
FWIW, if that's the way your car sits, IMO you're going to have to "crutch" the setup at the strip by putting on some big bias-ply slicks / MT ET Streets that will be less chassis-sensitive to hooking up than a DOT radial like an ET Street Radial.
Re: belt throwing... ya' got me. I run stock pulleys and have never had a problem even up to 7000.
Page 2 of 4 1 2 3 4
