650 hp in a street car.
#956881
03/23/11 12:52 PM
03/23/11 12:52 PM
Posts: 1,183 clarks summit pa
73cuda340
clarks summit pa
What is everybodys thought on 650 hp in a street car that will see a few trips to the strip? I have a 73 cuda that Im looking at getting a 472 hemi for. I want a fast street car that can put down good times at the track also, but not something that won't be any fun without running slicks all the time to get it to hook. Car is a 4 speed and currently 3.23 sure-grip 8 3/4 but will upgrade gears later. I plan on running 275/50 drag radials and either super stock springs or caltracs. What are your guys thoughts?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: 650 hp in a street car.
[Re: 73cuda340]
#956882
03/23/11 01:02 PM
03/23/11 01:02 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I got tired of a hairy engine, steep gears, and Texas heat. When I wanted more power I built a turbo engine so it would run around with nice street manners. When you got froggy it would spool up and run.
The monster street car sounds like fun but it can wear on you in short order.
[Re: feets]
#956883
03/23/11 01:13 PM
03/23/11 01:13 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
A real 650hp is not fun in a car that is street driven. You'll need to upgrade the whole rear, not the gears, BTW. A stick, drag radials, and a fairly heavy car will break the 8 3/4 quickly. Things like a more radical idle, 4 miles to the gallon, loud exh, almost unsafe driving in the rain due to power and gear changes, heavy clutch to ride in traffic... IMO if you have the cash for the Hemi, stick a turbo'd smallblock in it and make the same or more overall power but much less brutal with much less racey crud associated with driving it.
[Re: 73cuda340]
#956884
03/23/11 01:45 PM
03/23/11 01:45 PM
Posts: 4,179 California
mickm
California
a well built 472 can easily get you 600-650hp. well prepped heads is the key. a wide LSA cam (111-113) can give you a nice idle and give you a wide torque band, great for the street. i manage about 12mpg on the highway with mine if i don't lay into it, around town is 7-8, but also depends if i lay into it. tti exhaust with dynomax mufflers flow well and yet are quiet. a centerforce clutch handles it fine, and is not bad in traffic.
what some of the other posters said about turbos is true, but you can build a larger displacement engine with more mild specs and still get great horsepower out of it, and be very streetable.
and of course, if you want a hemi, there is no substitute.
i love mine. scatpk's 542 in his GTX dyno'd 542 at the rear wheels, before major carb adjustments, and it's a kitten to drive, until you lay into it. and it got 14mpg on the highway from san francisco to los angeles.
hard to beat.
if you want a hemi, this is all doable.
[Re: moper]
#956885
03/23/11 02:36 PM
03/23/11 02:36 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
This is so not true! (I'm sure if it was a Chevy or Ford it would be ) but I beg to differ regarding well-built thought out and built big block Mopars.
I'm running a "mildly cammed 550 lift hydraulic roller'd 493 cu inch sixpack with ported aluminum Indy EZ heads, a stick, McCloed street-twin, 325 50/15 drag radials rated to 186mph, factory 3.54 Dana, caltracs. It dyno'd at 684 horsepower at 5500 rpm with 682 ft lbs of torque.
It gets 8+ mpg around town and 12+ on the highway including an occassional romp or two. This is before I install Jamies 5 speed. My all stock 2000 Chevy Z71 pick-up and 5.6 litre V8 Mercedes only get 4 more mpg than it in either case......if I stay out of them all. Heck, my '68 slant six doesn't even get quite double the gas milage!
It's handles and stops great, drives and rides better than new and is so much fun to drive as to be drug-like in it's addiction. Especially when those outboards kick in.
Part of the fun includes seeing the general public's reaction to an old school, high compression big block with a lopy idle, especially when the exhaust cutouts are open.
I think Dave Hughes summed it best after the dyno session when he said, "It idles with authority...damm, it makes over 500 ft pounds of torque at 2000 rpm (he laughs). Torque is what makes it fun to drive on the street. Better buy stock in a tire company"
There's no way to fake that with a smooth idling turbo. Granted turbo cars are nice too, and I'm sure you could build a car the wrong way to enjoy 650 horsepower on the street, but to say all 650 horsepower cars are not fun to drive on the street, indicates you were not exposed to the right examples of 650 hp street-oriented builds.
Turbo smallblocks are nice, I'd like to have one in my slant 6 convertible, but it's just not the same viseral experience when that turbo's not spooled up though now, is it?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 73cuda340]
#956886
03/23/11 03:13 PM
03/23/11 03:13 PM
Posts: 319 Denver
Explodo
Denver
I'm wondering about that same thing myself. I want my car to be fun to drive, but not too much of a handful. I want my wife to not be afraid to drive my car.
How much power is fun to drive without being a problem? How much power is too much should you be caught out in less than ideal weather on a twisty road?
450hp? 550hp?
I don't know.
I want to hear more opinions.
'67 440 Satellite
[Re: jbc426]
#956887
03/23/11 03:30 PM
03/23/11 03:30 PM
Posts: 520 New Zealand
nz383man
New Zealand
I was so impressed with the street maners of a 605 Hemi car I had a ride in that I'm building one for my own '70 Barracuda now. The car was a '72 Roadrunner with a Indy built 605 Hemi with twin F.A.S.T. throttle bodies, full manual auto & Dana 60. The gas milage wasn't too bad as I filled my 383 at the same times on a trip & compared the difference. My advice . . . Do It!
[Re: Explodo]
#956888
03/23/11 03:33 PM
03/23/11 03:33 PM
jbc426
West Coast, USA
There are some people for whom 100 hp is too much. Cars have throttles for a reason. With the sixpack running on the center carb, it is very controllable, smooth, responsive and predictable, however when the outboards are tipped in; you better be sure about which way you have it pointed, because it goes off!
There is no question that 680 horsepower can make for a car that is intimidating to drive or ride in. I find it thrilling and satisfying, but not everyone is comfortable, experienced and/or responsible enough to safely manage that kind of power on the street, especially in wet weather.
[Re: jbc426]
#956890
03/23/11 04:00 PM
03/23/11 04:00 PM
Posts: 319 Denver
Explodo
Denver
If you have to be really careful with the throttle or be out of control, then I don't think that's what I'd consider a "great" car to drive.
'67 440 Satellite
[Re: 73cuda340]
#956891
03/23/11 04:10 PM
03/23/11 04:10 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
I use to race a 1970 Hemi 4 speed Cuda(not and originial )Have you weighed your car front to rear bias yet? If not do so soon Mine had 2168 lbs on the front tires with out me in it at the track scales and 1280 lbs. on the rear (or so, I can't remember the exact numbers now, but these #s are close)I took that car home after that race and sold it I have had numerous NHRA leagl Mopar drag race cars and street and strip car since then,A and B bodys with wedges and SB.One of my current street and strip car is a 1971 Duster with a Dana 60 (I twisted the 8 3/4 housing up real bad before it broke the ladder bar brackets off of the housing, it wasn't back braced ) and a 727 with several different pump gas BB combination motors in it, the car has ran a best of 10.34 at 128.6 MPH on pump gas, motor only, with the air cleaner and muffs on It puts a big grin on my face every time I drive it I had a lot of work done to the car while building it, I don't do chassis or paint and body work, to make it work like it does, I have broke a lot of parts with it also Speed costs money, how fast do you want to go (and can you afford ) A 4 speed with a hemi and a 8 3/4 rear end with good hooking tires will not live together very long Trust me on that There is a old adage about 4 speed cars that get raced,it goes "You have to feed the beast, you can feed it tires, clutches, transmissions, U joints, drive shafts or what ever you want to find that fails, but you have to feed it" It is true I built my current Duster with a cut down 8 3/4 out of full size 1964 Dodge B body narrowed with later model axle ends, Strange Engr. 35 spline race axles and spool, Mark Williams steel caps and a 742 case, A set of 1/4 Max ladder bars and single adjustable coil over rear shocks with a diagonal link I use M/T ET Street abd M/T ET Street Radials on it I still broke several ring and pinions, a new forged pinion yoke, trans yoke and finally twisted the housing up bad enough to break the ladder bar brackets off Luckily the brackets broke off on the starting line instead of down the track further at a higher speed I'm assuming your trans is a later model 833 with the small 23 spline input shaft with later gear ratios, 2.47 1st gear instead of the 2.66 or 2.65 1 st gear ratio early trans., if it 9not a 18 spline Hemi trans) is you will break it eventually if you hook the car up constitentily I'm not trying to talk you out of doing what you want to do, I am trying to provide you some insight on some of what has happen to me pursuing the need for speed. Be safe and have fun Don't cry to hard when it breaks Because it will Enjoy
[Re: Explodo]
#956892
03/23/11 05:30 PM
03/23/11 05:30 PM
jbc426
West Coast, USA
Control is a relative term. I consider myself in control when I'm rowing through the gears, violently launching forward with both rear tires smoking and the car drifting slightly from side to side, but these cars were engineered for that.
I'm really careful where I point my guns too, but I agree....some things are best left to those who can handle them.
[Re: Cab_Burge]
#956893
03/23/11 05:32 PM
03/23/11 05:32 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
No problem with a new car, lots of them can make 650hp with a bolt on supercharger or turbo and get 20 plus mpg and you can drive it daily. Ford will even let you keep the warranty on the new mustang if you use Ford motorsports parts.
A new iron curtain drawn across the 49th parallel
[Re: 67autocross]
#956894
03/23/11 05:59 PM
03/23/11 05:59 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
My car makes just a little less 650 hp and I'm going to be honest with you: it can be exhausting to drive on the street. Don't get me wrong - I enjoy driving it, but with the cam required to get the ponies around 600 hp, 4.10 gears, a loose converter (I know yours isn't an auto), and a reverse manual valve body, I get worn out just driving the thing to the gas station (which I do a lot ). ...and don't think that you don't need to upgrade a lot of other stuff too when you get over the 500 hp mark. Feets has a good point when he suggests thinking about turbos. As the San Angelo drag strip recently closed (see the thread in the race section), my car is now a "street only" car, and a really hard to drive one at that!
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 67autocross]
#956895
03/23/11 06:38 PM
03/23/11 06:38 PM
Posts: 319 Denver
Explodo
Denver
It's precisely because of things like this that I'm having trouble deciding between an all-aluminum 496 wedge and an all-aluminum 426 3G hemi. The hemi is so much more efficient and Bouchillon says it makes 600hp.
I think the wedge would be cooler and I'd have more of a sense of accomplishment because I'd have to build it.
The 426 weighs 50-100 lbs less, gets better mileage, and is likely to be plenty enough fun to drive. It just costs a bit more.
'67 440 Satellite
[Re: 73cuda340]
#956896
03/23/11 09:55 PM
03/23/11 09:55 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
My old truck is equiped with a tunnelrammed 528 hemi, the cam is 272/274@.050, 8" convertor, 4.56 gears with a spool. You can't wipe the grin off my face when I'm behind the wheel. It will drive or idle in traffic all day long without a hitch. The mileage isn't bad either all things considered. Two things come to mind though, you have to drive it according to the conditions, it can get away from you real quick if you act dumb. It WILL kill you if you let it. And if you're going to run it down the strip occasionally you WILL have to upgrade a few things. A Dana, better suspension, and some saftey equipment should be at the top of your list. If you're like me though after a couple weeks you'll get used to the power and NEED MORE. Dave
[Re: quickd100]
#956898
03/23/11 10:30 PM
03/23/11 10:30 PM
Posts: 12,216 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My Cuda has a 500" wedge 263* solid cam, 1050 Dom, fully auto 727, and 3.91s in an 8 3/4. 520 RWHP which puts it somewhere in the low 600s at the flywheel. The car has ran 6.8s @ 104 in the 1/8 and gets 11 mpg on pump gas on the open road. It is quiet enough to hear the radio at 60mph thanks to electric cut-outs.
I drive it to the track and to car shows regularly. And yes, you need to be very aware of the road conditions with that much power on tap. You can't kick into passing gear without the rear getting loose.....and that is at 45 or 50 mph.
The car is not difficult to drive at all with the automatic. But it does lope good. You would have no problem with a stick.
A well thought out combo will do what you want. You will probably need to make some changes after you get it together to dial in the exact combo that you like the best. But you can do it.
Go for it!
Master, again and still
[Re: DaveRS23]
#956899
03/23/11 11:12 PM
03/23/11 11:12 PM
Posts: 7,664 IN
ahy
IN
I run a +/-550 HP 496 wedge + 5 speed in a '70 Challenger. 8.75 rear. I do drive it with "respect" but is it a handfull? Not at all. Its set up for handling with stickey high speed tires, significant upgrades of the stock style suspension and 13" disks up front. If I ever had ambitions of drag racing it, I would add a Dana 60 pronto. But I don't so I won't. Actually, I've never nailed it in 1'st. That gear is just to get rolling. 2'nd and higher, its seen meaningful full throttle time.
The 8.75 served well on the big oval tracks for many years so it should handle a Silver State Classic run if I can get there some day.
I don't drive it in the snow... the HS tires turn to rocks at about freezing plus the body doesn't need the salt - but I do drive it in all other conditions. Last summer I drove it through a cloudburst. No problem.
Both daughters have driven it, my father in law has driven it but my wife won't. Only problem is the duaghters grew up on a DOHC Neon 5 speed and feel they have to rev the BB like the little 4 cylinder... especially daughter #1. Its "exciting" to take a ride with her.
550 HP is a lot but I wouldn't mind more some day. Fully port and shave the heads? A bit more cam? The shortblock can handle 600-650 without problem. We'll see.
Fuel consumption is 14 MPG @ 75 MPH, low teens in town and ?? if I really ride it. EFI + manual trans + overdrive help.
Beyond careful driving, a "balanced" car helps a lot. Suspension upgrades, tire upgrades and brake upgrades help make it fun (and safe) with increased power. Plus D60 rear end if you are drag racing.
[Re: ahy]
#956900
03/23/11 11:42 PM
03/23/11 11:42 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
I am with the turbo guys here.less cam,less gear and when the turbo is spooled up its the same power.Yes you dont have the lumpy idle,but you get better drivabilty out of it. Thats why i have a buick grand national and a mopar. The little buicks V6 is quicker than my 499 stroker,i can cruise on the highway @ 80 all day,get good mileage,click off 7.3s in the 1/8 and 60 foots in the 1.5s. And no niether are 600 horse but the difference between the 2 it isnt in the same league for driveabality.And any grandma could drive it with ease.
