Re: ever tried Adjust-a-jet on ur carb?
[Re: gsmopar]
#956549
03/23/11 06:23 PM
03/23/11 06:23 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
i have one of those on my 650 db pumper.it was used on my 340 and my 318,ive had it at least 10-12yrs now,had to remove the jets,add the plate,have to use there longer accelerator pump arm.keep in mind u also have to change the length of the fuel line, due to the distance between the fuel bowls being longer with this plate installed,thats only thing i remember running into with this kit.u can adjust the screw setting for more or less fuel,even with it idling,always worked good for me.they send a sheet with it for ball park jet settings.mike
[Re: hp340nos]
#956550
03/23/11 08:16 PM
03/23/11 08:16 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I've always wanted to try these but that's the first good thing I've ever heard about them^^^^^^
[Re: hp340nos]
#956554
03/23/11 10:40 PM
03/23/11 10:40 PM
Posts: 12,327 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Many, many moons ago I used them on my VolksWagon Beetles after I put hedders on them. They helped a little.
Master, again and still
[Re: DaytonaTurbo]
#956557
03/24/11 12:37 AM
03/24/11 12:37 AM
Posts: 673 Emmett, Idaho
SuperStockWagon
Emmett, Idaho
They look like they would be a nice toy, but once you have your jetting dialed in, you usually leave it alone, so after that point the adjust-a-jet would be kinda pointless.
IbadD50's home track is 4500+ ft elevation and corrected is usually 5500+ on good days, so most of the tracks he travels to are much lower corrected(or uncorrected)and much better air...so its really not pointless! ![](/ubbthreads/images/graemlins/rolleyes.gif)
