rocker arm shaft #956235
03/22/11 11:30 AM
03/22/11 11:30 AM
louisiana
mopar70charger Offline OP
louisiana
do you have to torque the rock arm shaft , if so how much torque ft lbs, on a 400 big block
Re: rocker arm shaft [Re: mopar70charger] #956236
03/22/11 11:44 AM
03/22/11 11:44 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Re: rocker arm shaft [Re: mopowers] #956237
03/22/11 12:04 PM
03/22/11 12:04 PM
louisiana
louisiana
thanks a lot..
Re: rocker arm shaft [Re: mopar70charger] #956238
03/22/11 10:05 PM
03/22/11 10:05 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
25 is correct and that's what it should be for the size of bolt used.
logan426
