Movin a 73-74 bumper in E-body. #956232
03/22/11 09:33 AM
03/22/11 09:33 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hi, I saw a picture of a 70 cuda with a 73-74 bumper mounted on it and moved in. I have a 74 cuda with the original bumper and both sets of mounting brackets, (72, 73-74). Can the 73-74 bumper be mounted on the 72 brackets?
Re: Movin a 73-74 bumper in E-body. [Re: cudabitten] #956233
03/22/11 12:32 PM
03/22/11 12:32 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Yes the bumper will mount fine on the 72 Brackets. The problem is the 73-4 Frame Rails have different holes for the bumper brackets so you will need to drill out the 72 bracket to match it to the 73-4 rail.....
Re: Movin a 73-74 bumper in E-body. [Re: QuickBpBp] #956234
03/22/11 12:42 PM
03/22/11 12:42 PM
Outside
thedriver Offline
thedriver  Offline
Outside
front bumper can be moved in with 73/74 brackets by removing the inner bumper bar, and then elongating the holes on the bumper brackets.
For the rear bumper you will have to use the 72 bumper brackets
1973 challenger
Dana. 4 speed. Low deck.
