Page 1 of 3 1 2 3
Anybody running an Edelbrock 750 on their big block? #956090
03/21/11 11:27 PM
03/21/11 11:27 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
I have a '65 Chrysler Newport Coupe with a mild 400. It has 452 heads, an older .470 lift hughes cam with matching valve springs, a double roller timing chain along with a high volume oil pump. It has a '69 383 intake along with a 750 Edelbrock as far as induction goes.
I am actually impressed with how it runs-especially for a big car!
Anyways, it does have single exhaust which is no doubt choking it back a little bit. That will go away when the funds allow. It has been converted to electronic ignition and uses the orange box.
I was wondering if anybody was using the Edelbrock 750? Mine needs to be tuned on for sure but I was looking for a good place to start with it. Jetting and things of that sort to make the best of what I have. I also have an Edelbrock performer 383 intake that will make it's way on there soon.
Also, any good suggestions for an alternator upgrade?? It does not have to look correct. When the carb's idle is dropped down to where it needs to be, the lights are dim at night.
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956091
03/22/11 12:50 AM
03/22/11 12:50 AM
IN
ahy Offline
ahy  Offline
IN
As far as the carb goes, I've never run it but I think you'll get lots of comments/advice.
For the alternator, you have several choices. Is it equipped with AC? I'll assume yes. That limits choices somewhat. The MOPAR alternator was never the best at idle. Dim lights is a common problem. The later "square back" alternator was better than the "roundback' of the mid sixties. The easiest/cheapest upgrade is a later model "square back" that should bolt in your existing brackets. The mid/late 70's version was rated at 78 amps vs about 50 max in the 60's. Two choices. Go to your autoparts store and order a 78 amp alternator for - say - a 1978 Diplomat or order a Powermaster alternator with similar rating from Mancini or Summit or Bouchillon. The alternator will bolt in but requires electrical upgrades to be reliable. The OE harness and especially bulkhead connector cannot handle the higher load. A wire of at least 10 guage, preferably 8 from the alternator to the fender relay will fix this. Install a length of 12 or 14 guage fusible link in the charge wire. With this modification the OE ammeter will not work and you will have to add a voltmeter or convert your existing ammeter to a volt meter.
With the alternator upgrade get a new regulator. If you keep the single field type, make sure its an electronic replacement (common at part stores) and ground one terminal of the newer dual field alternator. Or upgrade to the dual field regulator.
With quality problems on rebuilt alternators recently, I'd go the Powermaster route personally.
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956092
03/22/11 12:56 AM
03/22/11 12:56 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'd start at Edelbrock's website. They have a pretty solid tuning chart that will give you a good baseline of jet vs. rod combinations. read and understand all of their tuning advice, and don't make any changes until you feel confident that you understand what the change is trying to accomplish. Edelbrock does a pretty good job of supporting their customers, and their owners manual is a good read.
Unfortunately, you won't find a whole lot of positive reactions to the Eddy 750 on this board. Many, including myself, have had a bear of a time with them. I think most of these, however, were with pretty serious street / strip type efforts. If its a stock type street motor with a mild camshaft, you'll likely have good luck with it.
Great to hear you're enjoying your car
Re: Anybody running an Edelbrock 750 on their big block? [Re: StealthWedge67] #956093
03/22/11 06:38 AM
03/22/11 06:38 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
My GTX ran regular 12.6 with one through the exhaust with slicks and 3.23 gears.
Re: Anybody running an Edelbrock 750 on their big block? [Re: gdonovan] #956094
03/22/11 08:35 AM
03/22/11 08:35 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I had an edelbrock on a 440 and it ran well. I have had a demon, holley and eddy carb on the engine, All were able to be tuned to work well.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Anybody running an Edelbrock 750 on their big block? [Re: gdonovan] #956095
03/22/11 08:41 AM
03/22/11 08:41 AM
AZ
Mike P Offline
Mike P  Offline
AZ
I’ve been building AFB/AVS style carburators since the late 60s and they’re one of my favourites. Unfortunately finding OE AFB/AVS in the wrecking yards is a thing of the past and for the last several years I’ve had to buy NIB units on a few occasions. My experience is that quality control generally SUCKS....either that or it’s just my own bad luck.
I’m running a 750 on my stock 76 440. I put in on right out of the box and what a PIG. When I pulled the step rods what I found was that one of them had not been machined. Nothing like putting a cork in one of the jets to kill performance.
That being said it’s still a good design once all the bugs are worked out. I think you will probably find it’s going to be rich right out of the box. You will probably be able to correct this with a rod change and not have to change jets. You will also probably want to use a bit lighter spring under the pistons to delay the step rod lifting. Lastly you may find that you have to set the floats a bit lower to prevent heatsoak boil over if you live in a hot climate or high altitude.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: Anybody running an Edelbrock 750 on their big block? [Re: Mike P] #956096
03/22/11 09:36 AM
03/22/11 09:36 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
While I'm no fan of those carbs it should work fine for what you have. What you need to do is go buy a good timing light and vacuum gauge before you do anything. As mentioned go to the website and download any information you can on tuning tips. Usually I like to start by turning the mixtures screws in all the way then back out 1 1/4 turns. Turn them in/out until you get the best vacuum signal. Then I'd race the idle up to 2200-2400 and set your timing in full (no vac advance), 38* for your car should work. Then turn the idle back down to 800-1000 and check for best signal again. If you are having a stumble from cruise to WOT then you'll have to start messing w/ the rods. Good luck.
Coming soon!!!!
Re: Anybody running an Edelbrock 750 on their big block? [Re: Mr.Yuck] #956097
03/22/11 10:41 AM
03/22/11 10:41 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
Well I guess I may be in the minority here, but i've used Edelbrock carbs since way back when they were Carters.
On my 383 in the GTS when not serious about OEM stock I run an EDDY 750 on a Edelbrock DP4B intake. It really wakes up the 383. I have found that on new carbs straight out of the box they tend to run a bit rich. I leave the jets alone and go one step down on the metering rod and spring. That works well for me in street cars. (On my race carb I had a Holley 1050 on Team G (ported manifold) that gave me fits.)
I suggest you check out the Edelbrock site lots of info there and perhaps purchase one of their calibration kits.
Maynard
Re: Anybody running an Edelbrock 750 on their big block? [Re: ahy] #956098
03/22/11 11:08 AM
03/22/11 11:08 AM
N.Wilkesboro,NC
N.Wilkesboro,NC
Thanks!
Lots of good advice here!
The previous owner had bought the car from an estate sale of a Chrysler executive over 20 years ago and it was special ordered. It does not have air, which I believe is strange for being an ordered car.
I have located an alternator from a late 80's Dodge truck. It's not the Denso and it's fairly big. What are the thoughts on these? I believe it's application is from a '87 Ram 4x4.
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956099
03/22/11 01:12 PM
03/22/11 01:12 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The other thing to check is there are two Edelbrock Performer 750s. One is a leaned out (permanently) replacement for the mild 454/460 trucks - List #1407. One is a true performance 750 with the performance air bleeds - List #1411. No carb should be bolt on and go. So I would buy the strip kit and expect to tune it. Especially with a non-stock camshaft.
Re: Anybody running an Edelbrock 750 on their big block? [Re: moper] #956100
03/22/11 03:56 PM
03/22/11 03:56 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
I will look into the the strip kit. I noticed the rod for the accelerator pump is in the highest position (top hole).
It does tend to bor slightly..will this help?
The carb is the 1407.
Re: Anybody running an Edelbrock 750 on their big block? [Re: moper] #956101
03/22/11 04:39 PM
03/22/11 04:39 PM
been following all the eddy 750 complaints on here & never knew there were two of them . I wonder if the 1407 is the one drawing all the complaints
Re: Anybody running an Edelbrock 750 on their big block? [Re: RapidRobert] #956102
03/22/11 06:33 PM
03/22/11 06:33 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
If you're going to try and tune the carb, don't forget the step-up springs. They can make a big difference in how lean/rich it runs. Edelbrocks (in my opinion) don't usually require too much tuning out of the box, but Holleys take a little bit more tinkering to get right. Since you've already decided that you'd like to tinker, have you thought about switching to a Holley (I'm NOT trying to start a Edelbrock vs. Holley here, I'm just making a suggestion). I've had luck with both types of carbs. Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Anybody running an Edelbrock 750 on their big block? [Re: 1968RR] #956103
03/22/11 06:58 PM
03/22/11 06:58 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Search the edelbrock site the 1407 is the performance carb the 1411 is the one calibrated for the 454, and says it is 2% leaner. There appears to be a typo on there site where they show the 1407 where they should show the 1411.
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956104
03/22/11 08:39 PM
03/22/11 08:39 PM
IN
ahy Offline
ahy  Offline
IN
Thanks!
On the alternator, since you are't dealing with AC brackets, you have lots of choices. MOPAR used several alternators other than Denso in the 80's. I believe the Denso was the best.
The best retrofit solution is a 120 A Denso. It has lots of idle output. You can get the complete kit with brackets from Mancini (Andy F designed). The mid/late 70's 78 A square back from a parts store is the most budget friendly way to tackle this. With either, wiring upgrades mentioned are needed.
Re: Anybody running an Edelbrock 750 on their big block? [Re: moper] #956105
03/22/11 09:48 PM
03/22/11 09:48 PM
Puyallup, WA
Puyallup, WA
To the best of my knowledge. This both backwards and innaccurate. The 1407 is a manual choke version that is set up a little richer out of the box. The 1411 has an electric choke and is set up a little leaner. Niether is "Permanantly" leaned out. The jets, rods, and springs can be set up in either carb however you like.
Re: Anybody running an Edelbrock 750 on their big block? [Re: StealthWedge67] #956106
03/22/11 11:02 PM
03/22/11 11:02 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
I've run carter comp series 750 afb's years ago. 11.50's out of the box and no tuning in my 67 gtx. I'm sure if i ever get around to putting the "tune" to it, It may go a tenth or two faster.
Re: Anybody running an Edelbrock 750 on their big block? [Re: 6PACMAC] #956107
03/23/11 01:19 AM
03/23/11 01:19 AM
N.Wilkesboro,NC
N.Wilkesboro,NC
Sounds like I can do some stuff with it, so I may just try that.
I did pull a couple of the plugs and it definetly indicated that it is running a little on the rich side.
Is Demon Sizzler still building Thermoquads??
Re: Anybody running an Edelbrock 750 on their big block? [Re: 1968RR] #956108
03/23/11 01:50 AM
03/23/11 01:50 AM
N.Wilkesboro,NC
N.Wilkesboro,NC
I have a Holley that is good but I am afraid the 600 is way to small. I already have the Edelbrock and it's not to old...
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956109
03/23/11 09:29 AM
03/23/11 09:29 AM
scratchnfotraction Offline
before you swap alt,get one of the newer solid state elect voltage regulators to replace the old points type you have with the round back alt with one feild wire
this will help the dim lights at idle and works way better than the points style VR
best 12$ upgrade I did to the 68Dart I had
you can run a square back alt by grounding the 2nd feild wire and hook the other up for an up grade, the one from the truck should bolt right in place of yours
you can use an external regulater denso 120 amp(late 80s cars/trucks/vans) on stock non a/c pullys,has the double grooved belt pully on it and works on the stock external VR for a good upgrade
i have one on my 440 in the sig pic on stock brackets,you just crimp on eyeloops for the 2 feild wires and bolt it on
IMHO,I would do the 12$ replacement VR first and see if that fixes it enuff for you,before changing the stock alt for another
x2 on a timeing light and vac gauge to start tuneing on the carb,all 3 work together to dial it in
good luck
Page 1 of 3 1 2 3
