Re: 2000 dodge caravan 3.3 flex with code p0205
[Re: Dakota_Don]
#956050
03/21/11 11:03 PM
03/21/11 11:03 PM
Posts: 198 Staten Island, NY
Theorio1025
Staten Island, NY
What do you mean by repaired the circuit? Was there a fault, or did you just replace the wiring? Have you tried scoping out the # 5 injector circuit? Also it may be a false code caused by a bad pcm.
Re: 2000 dodge caravan 3.3 flex, any dodge techs here
[Re: DartGTX]
#956052
03/21/11 11:25 PM
03/21/11 11:25 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
ok here is what found when the hood was open..
towards the front, drivers side, the 6 inj wiring was frayed.. fixed that.. it ran better.. pcv hose off, fixed that.. now after the codes were reset.. it still has number 5 circuit mal-function. so i pulled the plenum off, checked the wiring under it.. it all looked good..ohmed out the inj and it was approx 12.9 range..used a noid light to check the wiring, it flashed as it should have. I dont think that inj is bad..it ohmed like all the others.. it has a bad miss, also if i pull number 5 wire off the coil pack nothing changes still runs the same. fire wall now the inj order is pass side 1-3-5 driver side 2-4-6 radiator thanks again
