radiator (again) #955900
03/21/11 08:57 PM
03/21/11 08:57 PM
ohio
geol Offline OP
geol  Offline OP
ohio
The radiator I have for my 72 Duster by part number is for a 225 6cyl with A/C.Its a 22 inch and appears to have 3 cores.My question is will this be sufficient to cool my 340 with about 350 hp?
Re: radiator (again) [Re: geol] #955901
03/21/11 09:49 PM
03/21/11 09:49 PM
Yes IF the cores are not plugged and rodding out is an option for an OE rad but it can weaken the tube walls (alot depends on the care the rad shop guy takes w it) and you'd want a shroud/properly spaced solid steel or MP thermal clutch fan w steel blades (no flex fans),good airflow into the rad, smallest WP pulley you can find/fit, anticav plate
Re: radiator (again) [Re: RapidRobert] #955902
03/22/11 08:33 AM
03/22/11 08:33 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Sounds like good advice. Don't get talked into aluminum or flex fans.
