Re: Rollcage Paint, Car is already painted
[Re: Kam*Kuda]
#955670
03/22/11 03:40 PM
03/22/11 03:40 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Leave it bare. The rat rod look is in ![](/ubbthreads/images/graemlins/thumbs.gif) I used the hammer tone stuff myself.
[Re: Kam*Kuda]
#955674
03/22/11 06:27 PM
03/22/11 06:27 PM
Posts: 2,286 Hamilton,Ont
72chrgrally
Hamilton,Ont
Chassis inspectors don't like hammer tone paint because it makes the thickness readings incorrect with the sonic tester. ![](/ubbthreads/images/graemlins/Twocents.gif) Steve
Photobucket sucks
[Re: 72chrgrally]
#955675
03/22/11 07:06 PM
03/22/11 07:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
They just scrap the paint off(or make you do it) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Crazy68Dart]
#955676
03/22/11 07:30 PM
03/22/11 07:30 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
Here is brushed por15.
Wow that looks great ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Runner]
#955678
03/22/11 07:54 PM
03/22/11 07:54 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Word of advice, and recommended by por15, put the stuff on bare, do not prime first.
I had the cage primed when the car was painted because I didn't know what I was going to do with the cage. The door bars and cross bar were out of the car and did not get primed.
The stuff that was *not* primed painted and came out better. The guy that painted the car could not believe it. I mean, glass smooth. I hung the pieces vertically from the ceiling with some wire, that way it was easy to spin as you paint.
The cage in the car came out really nice too, don't get me wrong. There is just some dust and stuff that was in the primer, plus the por15 did not flow out as well as bare metal. Still super smooth, but I could tell a difference when painting.
383, Hemi 4-Speed, AlterKtion, D60
[Re: Crazy68Dart]
#955680
03/22/11 11:02 PM
03/22/11 11:02 PM
Posts: 1,340 Pennsylvania
proshiftcharger
Pennsylvania
just FYI..... Regarding the POR 15, its great stuff and you can apply it with a brush and watch your brush marks disappear. Keep in mind for whats its worth, POR 15 is UV sensitive and if exposed to direct sunlight the paint will discolor. POR 15 sells a top coat that is UV protective called Blackcoat which will secure/protect your POR15 base coat color. You can brush or spray it on and I believe its available in a rattle can also. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: rowin4]
#955685
03/27/11 03:35 PM
03/27/11 03:35 PM
MR_P_BODY
What are you talking about 'won't last " I put por 15 on my bare floor pans over 5 years ago and there is no ware or chips, a door bar might get some scratches from rolling in and out of the car but the rest of the bar will be perfect for years.
I just got done painting my trans with Chassis Saver but I found out that its UV sensitive also, so when it comes to painting the cage inside I need to cover it with a clear UV enamel paint ... the Chassis Saver is the same as POR-15 just cheaper and thats what alot of the semi trucks use ![](/ubbthreads/images/graemlins/wave.gif)
