Re: Rollcage Paint, Car is already painted [Re: Kam*Kuda] #955670
03/22/11 03:40 PM
03/22/11 03:40 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Leave it bare.
The rat rod look is in
I used the hammer tone stuff myself.
Re: Rollcage Paint, Car is already painted [Re: The Shadow] #955671
03/22/11 06:11 PM
03/22/11 06:11 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Here is brushed por15.
383, Hemi 4-Speed, AlterKtion, D60
Re: Rollcage Paint, Car is already painted [Re: Crazy68Dart] #955672
03/22/11 06:12 PM
03/22/11 06:12 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
2
Re: Rollcage Paint, Car is already painted [Re: Crazy68Dart] #955673
03/22/11 06:13 PM
03/22/11 06:13 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
3
Re: Rollcage Paint, Car is already painted [Re: Kam*Kuda] #955674
03/22/11 06:27 PM
03/22/11 06:27 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Chassis inspectors don't like hammer tone paint because it makes the thickness readings incorrect with the sonic tester.
Steve
Photobucket sucks
Re: Rollcage Paint, Car is already painted [Re: 72chrgrally] #955675
03/22/11 07:06 PM
03/22/11 07:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Steve
They just scrap the paint off(or make you do it)
Re: Rollcage Paint, Car is already painted [Re: Crazy68Dart] #955676
03/22/11 07:30 PM
03/22/11 07:30 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Wow that looks great
Re: Rollcage Paint, Car is already painted [Re: Kam*Kuda] #955677
03/22/11 07:47 PM
03/22/11 07:47 PM
Idaho
Runner Offline
Runner  Offline
Idaho
you should be able to get por 15 at your local paint store. the stuff is tough!
Re: Rollcage Paint, Car is already painted [Re: Runner] #955678
03/22/11 07:54 PM
03/22/11 07:54 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Word of advice, and recommended by por15, put the stuff on bare, do not prime first.
I had the cage primed when the car was painted because I didn't know what I was going to do with the cage. The door bars and cross bar were out of the car and did not get primed.
The stuff that was *not* primed painted and came out better. The guy that painted the car could not believe it. I mean, glass smooth. I hung the pieces vertically from the ceiling with some wire, that way it was easy to spin as you paint.
The cage in the car came out really nice too, don't get me wrong. There is just some dust and stuff that was in the primer, plus the por15 did not flow out as well as bare metal. Still super smooth, but I could tell a difference when painting.
Re: Rollcage Paint, Car is already painted [Re: Crazy68Dart] #955679
03/22/11 08:10 PM
03/22/11 08:10 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Nice car But for some reason I thought you were building a Kam-Kamino
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Rollcage Paint, Car is already painted [Re: Crazy68Dart] #955680
03/22/11 11:02 PM
03/22/11 11:02 PM
Pennsylvania
proshiftcharger Offline
Pennsylvania
just FYI.....
Regarding the POR 15, its great stuff and you can apply it with a brush and watch your brush marks disappear.
Keep in mind for whats its worth, POR 15 is UV sensitive and if exposed to direct sunlight the paint will discolor. POR 15 sells a top coat that is UV protective called Blackcoat which will secure/protect your POR15 base coat color.
You can brush or spray it on and I believe its available in a rattle can also.
Re: Rollcage Paint, Car is already painted [Re: G-Money1320] #955681
03/23/11 12:14 AM
03/23/11 12:14 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I make one comment and it stays with me for life LOL
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Rollcage Paint, Car is already painted [Re: Kam*Kuda] #955682
03/24/11 02:17 AM
03/24/11 02:17 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Hey Rob,
This looks awesome! big difference from when I seen it years ago.
Re: Rollcage Paint, Car is already painted [Re: torkrules] #955683
03/24/11 03:01 AM
03/24/11 03:01 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
that car is too nice for por 15,the finish isn't the best and It won't last as long as you think.
It isn't much more work to mask everything off and spray it.you won't want to do it twice.
Re: Rollcage Paint, Car is already painted [Re: west] #955684
03/27/11 03:16 PM
03/27/11 03:16 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
What are you talking about 'won't last " I put por 15 on my bare floor pans over 5 years ago and there is no ware or chips, a door bar might get some scratches from rolling in and out of the car but the rest of the bar will be perfect for years.
Re: Rollcage Paint, Car is already painted [Re: rowin4] #955685
03/27/11 03:35 PM
03/27/11 03:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just got done painting my trans with Chassis Saver
but I found out that its UV sensitive also, so
when it comes to painting the cage inside I need
to cover it with a clear UV enamel paint ... the
Chassis Saver is the same as POR-15 just cheaper
and thats what alot of the semi trucks use
