trans question #955595
03/21/11 03:26 PM
03/21/11 03:26 PM
Brandon, Manitoba, Canada
Roadripper Offline OP
i am rebuilding the trans in my dodge 4x4 , 440 ,727 auto , i came to the part in the factory service manual for band adjustment that says ! tighten adjuster screw to 72 inch pounds and then back out 2 turns . now is that 2 full turns back ??? wasn't sure had to ask lol thought i would ask the experts out there thanks mike
Re: trans question [Re: Roadripper] #955596
03/21/11 03:58 PM
03/21/11 03:58 PM
Correct
Re: trans question [Re: RapidRobert] #955597
03/21/11 06:28 PM
03/21/11 06:28 PM
scratchnfotraction Offline
correct,hold the adjuster from turning when you lock the lock nut down
a 1/4" drive 8 point 5/16" socket is just right,I painted a line down mine to help count the turns when doing them in the car/truck from the bottom side
if you dont have an inch pounds torque wrench a foot pounds wrench that goes down to 6 foot pounds works
or just snug it good by hand with a 5/16 wrench and back it out 2 turns
Re: trans question [Re: scratchnfotraction] #955598
03/22/11 01:45 AM
03/22/11 01:45 AM
thanks guys , figured i read the manual right just had to be sure
