Disadvantages of E85 on street strip car? #955241
03/21/11 01:21 PM
03/21/11 01:21 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
What are the disadvantages of E85 on a street/strip car? Is there any issue if the car sits for a couple of months? What needs to be changed beside the carb?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Disadvantages of E85 on street strip car? [Re: 65 Hemi] #955242
03/21/11 02:26 PM
03/21/11 02:26 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
All I can tell you is that you need a metal type fuel filter. The E85 will break down paper elements.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Disadvantages of E85 on street strip car? [Re: bigsbigelow] #955243
03/21/11 03:09 PM
03/21/11 03:09 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Availability of stations that have it.
Re: Disadvantages of E85 on street strip car? [Re: bigsbigelow] #955244
03/21/11 04:23 PM
03/21/11 04:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Ruin paper element fuel filters? I ran it all the time in my 68 cuda with a see through paper element and have never had a fuel system related problem. Never saw it "clean all the rust out of the tank" or even had 40 year old rubber line give me an issue. I think a lot of guys have issues they just want to blame on the ethanol. It is actually a preservative and not corrosive, you can drink straight ethanol and live to tell.
Re: Disadvantages of E85 on street strip car? [Re: HotRodDave] #955245
03/21/11 04:53 PM
03/21/11 04:53 PM
bigsbigelow Offline
bigsbigelow  Offline
Okay, I will reword my post. Some of the adhesives used in paper filters have been known to break down from the use of E85. The paper itself doesn't. Which brand of filters fail? I do not know. Google e85 and fuel filters. You will find a plethora of information.
Re: Disadvantages of E85 on street strip car? [Re: 65 Hemi] #955246
03/21/11 05:02 PM
03/21/11 05:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've left a full tank in my car over the winter and
it fired right up in the spring... now days just to be
on the safe side I drain it and add just regular gas
and idle on it while I pour in oil into the carb while
it just runs out of fuel(to lube the bores)
Re: Disadvantages of E85 on street strip car? [Re: astjp2] #955247
03/21/11 09:11 PM
03/21/11 09:11 PM
NC
440Jim Offline
440Jim  Offline
NC
That was my thought.
The first year I ran E85 with a carburator, I used my old Fram HPG-1 fuel filter (paper element); and after checking it a couple times during that period (including the end), the element was just fine.
Re: Disadvantages of E85 on street strip car? [Re: astjp2] #955248
03/21/11 09:46 PM
03/21/11 09:46 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
It is more available in this area than race gas.
Doug
MOPAR or NO CAR!!!
Re: Disadvantages of E85 on street strip car? [Re: 65 Hemi] #955249
03/21/11 09:52 PM
03/21/11 09:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The only thing about storing the car for long periods
is the ethanol will absorb water... the water is the
problem.... you could seal the vent BUT the expansion
will be a problem
Re: Disadvantages of E85 on street strip car? [Re: MR_P_BODY] #955250
03/22/11 12:40 AM
03/22/11 12:40 AM
will be a problem
Condensation in the fuel tanks, metal or in fuel cells,is a big problem in airplanes that sit long peroids of times, especially in wet climates Alcohol of most types suck water out of the atomshpere, mixed with water Methannol makes acids that kills aluminum I don't know about ethanol, probally not like Methanol at all Anyone know for sure the results on ethanol and water mixed together?
Re: Disadvantages of E85 on street strip car? [Re: Cab_Burge] #955251
03/22/11 01:15 AM
03/22/11 01:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It doesnt create any issues... just the water itself
is a problem... I pulled my metering blocks last year
and had a little bit of corrosion... cant say exactly what
caused it
Re: Disadvantages of E85 on street strip car? [Re: MR_P_BODY] #955252
03/23/11 12:53 AM
03/23/11 12:53 AM
Glendale AZ
Comp Chassis 2 Offline
Glendale AZ
Have converted 4 cars, so far the only thing I have found is a little corrosion on the main body behind the metering blocks. Nothing as far as the fuel cell (alum) or the filters or pumps. Have inspected all of them. Looking into getting the main body of the carb anodized, I know it can be done just don't know who to have do it! Any ideas? I have seen aftermarket carbs done, had a set of Books that were anodized, maybe I'll call them. If anyone has a source to do this please let me know,as I would like to remedy to problem before it eats the main body past the point of repair. Thanks.
Re: Disadvantages of E85 on street strip car? [Re: Comp Chassis 2] #955253
03/23/11 01:46 AM
03/23/11 01:46 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I'm convinced, e85 for me, when I get my car going.
But also want it efi.
Re: Disadvantages of E85 on street strip car? [Re: B1KILLER] #955254
03/23/11 12:23 PM
03/23/11 12:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
XFI for that one. The EZ efi unfortunetly will not work with E85...
I was thinking about it for my latest car, but very few stations carry it, even though I am one town away from the plant that makes it.
Re: Disadvantages of E85 on street strip car? [Re: astjp2] #955255
03/23/11 01:09 PM
03/23/11 01:09 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Around here, that's the main disadvantage.
A couple buddies who use e85 both upgraded their cell phones to gps capable units, and then programmed in every station they could find within a couple hundred mile radius of home, to try to solve the availability issue....
Rich H.
Esse Quam Videri
Re: Disadvantages of E85 on street strip car? [Re: Comp Chassis 2] #955256
03/23/11 01:21 PM
03/23/11 01:21 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Google DIY anodizing and you will find many articles explaining how to do it yourself. Small parts like carbs can be done in a bucket.
http://www.google.com/search?q=diy+anodi...images&tbs=
Or just try this link. http://www.caswellplating.com/kits/index.html
But anodizing would only work with aluminum carbs. The majority of Holley carbs are zinc and I think would need to be nickel or chromate coated.
You might get some ideas from these two links.
http://www.caswellplating.com/kits/alzinc.htm
http://www.martechholdings.com/chromates.html
Re: Disadvantages of E85 on street strip car? [Re: Dragula] #955257
03/23/11 01:22 PM
03/23/11 01:22 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Did you go to the E85 gas station search? There are a few around you and one in Lockport itself. I have ran E85 all last year and love the stuff.I just started the car up 4 days ago when we had spring. (now we are back to winter and snow today ) I just poored alittle straight gas in and when it fired up switched over to E85 that has been in the fuel cell since September. No problems at all.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Disadvantages of E85 on street strip car? [Re: slippery440] #955258
03/23/11 01:43 PM
03/23/11 01:43 PM
Dragula Offline
Dragula  Offline
I did a search, and closest one it showed was Tonawanda, please post the link to the one you used.
Re: Disadvantages of E85 on street strip car? [Re: Dragula] #955259
03/23/11 02:51 PM
03/23/11 02:51 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
www.growthenergy.com There is one at 95 South Transite in Lockport. Three more within 10 to 20 miles. They are showing up more around Rochester. I live in Penn Yan and the closes is about a hour away. I use E85 only in the drag car so when I go get fuel I get it by the barrel full. I use anywhere from 6 to 10 gallons a day racing.I really think that you will see more gas stations with E85.
Re: Disadvantages of E85 on street strip car? [Re: Dragula] #955260
03/23/11 03:07 PM
03/23/11 03:07 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Just run a flex fuel sensor. I have one in my dart with the xfi works great. The only downside to e-85 in my book is you need to fill up more often. So I am getting this next
http://www.jegs.com/i/Aeromotive/027/18663/10002/-1
