Timing Chain Removal? #954370
03/20/11 10:41 AM
03/20/11 10:41 AM
Mashpee,MA
mopar360 Offline OP
Can't start my lawn mower
mopar360  Offline OP
Mashpee,MA
Hey guys,
So im taking apart my 360 ci. engine for overhaul and im at the timing chain, is there a certain puller needed to remove it? Any tips on removal are wanted.
Thanks,
Ethan
All throttle...No bottle! 1979 Chrysler 300 (360) 1984 Chrysler 5th Avenue (318)
Re: Timing Chain Removal? [Re: mopar360] #954371
03/20/11 11:18 AM
03/20/11 11:18 AM
can use a gear puller on the crank gear just put something on the bolt hole threads to protect them but prob can CAREFULLY wedge it w 2 screwdrivers to get it started moving forward. Just use care as to not gouge anything
Re: Timing Chain Removal? [Re: RapidRobert] #954372
03/20/11 05:09 PM
03/20/11 05:09 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the cam gear and the crank gear need to move forward together other wise ..one will bind the other and nothing will move.
Tony
70 AARCuda Vitamin C
Re: Timing Chain Removal? [Re: 70AARcuda] #954373
03/20/11 05:22 PM
03/20/11 05:22 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Shouldn't need a puller. A pair of screw drivers to work the sprockets off is all I have ever used.
Re: Timing Chain Removal? [Re: MoparforLife] #954374
03/26/11 02:44 AM
03/26/11 02:44 AM
5thAve Offline
5thAve  Offline
Every time I dig into them the timing chain is so worn out you can pull it right off. The gears are another story
