found 2 problems racing today
#954268
03/20/11 04:42 AM
03/20/11 04:42 AM
Posts: 4,647 aotearoa
rebel
aotearoa
our season is at an end & we had our national series final today. while competing i found i have 2 problems developing with my car. first is my transbrake is allowing me to creep forward about 2" before it locks up & holds the car. before we increased the line pressure from 100 odd to 150 psi it would instantly stop but now it allows movement. is this my brakes(VB) fault or is something amiss with the trans? (A&A Ultimate LBA brake) secondly my increased height 6 pak scoop is trying to rip itself off the hood. i don't think it likes 140 mph & i think i'll have to replace it with a cowl scoop. anybody else have problems with their 6 pak peeling off?
Re: found 2 problems racing today
[Re: rebel]
#954270
03/20/11 09:40 AM
03/20/11 09:40 AM
Posts: 2,933 A shed in England
Tig
A shed in England
Can't comment on the trans problem either but we had a steel strengthening "rib" 'glassed into ours behind the centre strut. It actually broke the glass one, also it was trying to remove itself from the hood as is yours I suspect. We put in extra bonnet pins and had the areas where the scoop attaches to the hood reinforced with glass at the same time the strut was fitted. Made the hood a bit heavier but all is good now, hoping to test it at 145mph soon HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: rowin4]
#954272
03/20/11 11:56 AM
03/20/11 11:56 AM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I have a standard six pack scoop (not extended hight) glassed on a homemade glass hood, that is pinned at the 4 corners. I only run 130 mph in the qtr mile, but the scoop literly trys to lift the hood off the car, and has small cracks around the corners of the scoop. Running 1/8 mile, I don't have any problems, but only running 105 mph. I have seen others that used extra hood pins or carb studs, I really don't want to add one, but going to have to do something. As far as the trans problem, there is no way to have consistant reaction times when the car moves that much before it takes a "set".
Brian Dunnigan
[Re: Mtn Thunder]
#954279
03/20/11 11:02 PM
03/20/11 11:02 PM
rebel
aotearoa
thanks for your feedback guys. i know it's not low voltage or bad earth, i've checked with the motor off & can very distinctively hear the solenoid click when i activate the button, i only need to depress the button 0.020 to activate & it clicks exactly on time every time so it's not electrical. the rollout is rpm relative as if the idle is low, e.g.900 rpm it rolls less than when it's high at 1100 rpm, it's just as the engine warms up the rpm tends to creep up too. i'm using dex3 fluid so i can eliminate the fluid issue. the trans is race built so i'm resonably sure it's tight tolerances on the band. we only started having this problem with the creep when i bumped up the line pressure. i'm not having much luck getting an e-mail back from A&A so i'm not 100 on the correct line press on their lba brakes. maybe i should go back ??
as for the 6 pak scoop, last season i had it enlarged to make room for the dominator. before that it survived 6 seasons with only minor stress cracks around the pins. my front end is a one piece, not just a pin on hood. within a few meetings of enlarging the 6 pak we noticed the carbon had cracked around the pins, but this weekend we could see it was cracking almost 1/8" on every pass. i'm seriously considering a long full length cowl, i know it's not mopar but to be honest, there aint that much stuff on my car that is these days, just some of the main shell, a bit of floor & the front chassis along with a 727 case. can anyone supply a pic of a dart with a full length cowl please. i know there have been pics on past posts but i never considered them an option until now so i never paid them any attention. funny how opinions change huh? cheers again for the feedback guys, appreciate it.
[Re: rebel]
#954283
03/22/11 05:28 AM
03/22/11 05:28 AM
Posts: 461 Hinterland SE Qld Aust
SG duster
we were out of the competition
what compititions that?? you had 2 enrtys in your class and got palmed off into another class who also had very low numbers , come on ol m8, thats not the New Zealand Nationals of the past with hundreds of entrys & full feilds, whats happened??
well deserved congrats on the pb by the way .
[Re: rebel]
#954284
03/22/11 06:51 AM
03/22/11 06:51 AM
Posts: 14 Brisbane Australia
raven
Brisbane Australia
sure did raven, we were out of the competition so we set the tune on kill & was trying to beat our personal best, but then we were asked to take the track sponsors daughter for a ride. we were very happy with that time considering the extra weight, we know we can run a 9.3 with our smaller carb with the right conditions.
thats excellent Reb, well done i came & talked to you at last years nostalgia meet, thats one sweet ride. my cousin also told me Marsh broke your track record again, you guys are getting some hot cars at your track now, thats good to see. hope to get back & watch next years nostalgia meet & maybe catch up again, good luck for the 3rd.
