low budget build #954065
03/19/11 11:23 PM
03/19/11 11:23 PM
ct
jkgtx Offline OP
jkgtx  Offline OP
ct
took my old 440 trw 2295 slugs,threw in new set eagle rods milled the domes off.065 in the hole,452 heads fresh valve job pc seals ss 2.14-1.81 valves,500sh hyd cam ebay waistegate blowoff valve,series 60 detroit disel garrett turbo,750 holley I modded for blow thru,used hat,adding some methanal for cooling,any guesses on power 8 psi or more,pulling my indy headed 512 out to play with this always wanted http://www.youtube.com/watch?v=AsU9RnmKdkgturbo
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
Re: low budget build [Re: jkgtx] #954066
03/20/11 12:15 AM
03/20/11 12:15 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
750hp at 8#.
nice video with a scary ending.
Re: low budget build [Re: jkgtx] #954067
03/20/11 12:34 PM
03/20/11 12:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I dunno but my cast piston 8:8.1 440 with stock 906 heads, summit 488 cam, RPM intake, Proformed 750DP, headers, 175k convert, 3.91's went 12.08 @114 at 6psi of boost off a SN-2000 supercharger. This was in a full steel 3850lb 67 coronet. Probably had more in it. Your's should have at least second more in it, more boost, bigger cam, less drag on the engine (no belt) cool, drop it in and lets see the boost gauge jump.
Coming soon!!!!
Re: low budget build [Re: jkgtx] #954068
04/16/11 08:34 PM
04/16/11 08:34 PM
ct
jkgtx Offline OP
jkgtx  Offline OP
ct
http://youtu.be/tCjwdTxhbbQ
update on engine in car need to upgrade fuel system,electric fan,afr meter,methanal inj but it fit
Re: low budget build [Re: Mr.Yuck] #954069
06/03/11 10:55 PM
06/03/11 10:55 PM
ct
jkgtx Offline OP
jkgtx  Offline OP
ct
well dead rich first run 10 a/f 12.67 114 mph
jetted down ran 11.97 117mph motor sounding funny found bad rocker adj put in a set 4.10 trying it tommarrow converter way too loose but want to do some shakedown runs:)
Re: low budget build [Re: jkgtx] #954070
06/03/11 11:01 PM
06/03/11 11:01 PM
ct
jkgtx Offline OP
jkgtx  Offline OP
ct
Re: low budget build [Re: jkgtx] #954071
06/05/11 12:26 PM
06/05/11 12:26 PM
ct
jkgtx Offline OP
jkgtx  Offline OP
ct
well made it to track about 6 runs last 3 runs
11.50s at 117 mph one run 118 mph converter would stay at 6000 rpm no matter what gear lol too loose pulls really hard but way out of rpm range of torgue
Re: low budget build [Re: jkgtx] #954072
06/09/11 12:16 AM
06/09/11 12:16 AM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
All I can say is SWEET !!!!!!!!
Hats off to ya mate !!!!!
I have been busy with some of my other junk but gonna take my 68 Belvedere to the track soon.
