thanks for the info guys. i'll check both van, and dakota set ups, to see if either will work.but, if worse comes to worst, i do have some bare flanges so i could buy tubing, and build my own.i should have known there was no "total" easy way. either have the serpentine system(one belt, no alignment issues, plus newer, higher output alternator),and build headers.or bolt on manifolds, y pipe, and hang the turbo on it, but convert back to v belt, and try to get everything aligned. oh well, it hasn't whipped me yet. thanks again.
