I read a number of the threads on this and I saw a lot of feedback.
What is a good quality breather? I go have one of the Mr Gasket that have the hose attachemnts that go to the back of my air cleaner - should I lose that and go to something else?
I also will check and see if I am pulling any suction from the PCV valve - is there one that works better than others? I have a (440, and eddelbrock 84 cc heads, Comp Cams Hydraulic roller and a 6 pack set up).
I am running baffles already.
