70-72 B body sway bar in a 65 K frame #953260
03/18/11 06:01 PM
03/18/11 06:01 PM
Northwest
Four40mopar Offline OP
Northwest
I am thinking about modifying a 65 B body K frame to accept a 70-72 B/E sway bar. Has anyone done this, or thought about doing this? What do you think?
Re: 70-72 B body sway bar in a 65 K frame [Re: Four40mopar] #953261
03/18/11 06:31 PM
03/18/11 06:31 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I compared the 65 and 69 K frames. The 69 bar brackets will bolt on after you drill the holes.
I have no idea about the later sway bar.
- Stu Harmon
Re: 70-72 B body sway bar in a 65 K frame [Re: feets] #953262
03/18/11 07:02 PM
03/18/11 07:02 PM
Northwest
Northwest
I was going to put a 70-72 K frame in my 65 B body to get the integrated sway bar, but after some research I found it might create other unwanted problems. You are right the outer bracket will bolt on after drilling holes. The modifying would involve creating clearance notches in the frame. The only picture of a 70-72 K frame on ebay is attached. Look at the outer edge near where the brackets would bolt on.
Re: 70-72 B body sway bar in a 65 K frame [Re: feets] #953263
03/18/11 07:04 PM
03/18/11 07:04 PM
Northwest
Northwest
Sorry that picture is worthless
Re: 70-72 B body sway bar in a 65 K frame [Re: feets] #953264
03/19/11 11:13 AM
03/19/11 11:13 AM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
So you're saying that with just drilling the holes in the K and using 66-69 LCAs with the bracket, a 66-69 Sway bar will bolt in? I never thought of that and its good to know. Thanks
Re: 70-72 B body sway bar in a 65 K frame [Re: 65Frank] #953265
03/19/11 04:09 PM
03/19/11 04:09 PM
Northwest
Northwest
I think a 66-69 sway bay on a 65 K frame w/ 66-69 LCA's would be pretty easy, just drill the holes in the front lip. I know 65 B bodies had an optional sway bar, but I don't believe I have ever seen one.
Re: 70-72 B body sway bar in a 65 K frame [Re: feets] #953266
03/19/11 05:07 PM
03/19/11 05:07 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
This is what a '65 B-body sway bar looks like. The ends clamp to the strut rods so no special control arms needed. This setup was used from 1964 to early 1966.
Re: 70-72 B body sway bar in a 65 K frame [Re: NicksGarage] #953267
03/19/11 05:16 PM
03/19/11 05:16 PM
Northwest
Northwest
Thanks, I wonder if any company reproduces that set up? As far as I know they push the adapted 66-69 bar.
Re: 70-72 B body sway bar in a 65 K frame [Re: Four40mopar] #953268
03/19/11 06:17 PM
03/19/11 06:17 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I don't think anyone makes them. Kind of an obscure setup. The best thing about them is that they simply bolt on without changing any parts. The easiest place to find them is early '66 Chargers.
