Cuda Rallye Rim Clearance #953203
03/18/11 04:22 PM
03/18/11 04:22 PM
Long Island, NY
70plymA34 Offline OP
Long Island, NY
My 70 440-4 Cuda originally came with 14" rallyes. When the car is done I want to upgrade to a 15" rallye rim with E60X15 polyglas tires. Is there going to be any problems installing these onto a car that originally came with 14's . Are the wheels going to touch the fenders at all?? Is this going to work without modification?? Any info would be greatly appreciated.
Re: Cuda Rallye Rim Clearance [Re: 70plymA34] #953204
03/18/11 04:32 PM
03/18/11 04:32 PM
Northern Virginia
Moparmaniacc Offline
Northern Virginia
No problems with E60 x 15 at all, if you use 15 x 7.
FYI, I just installed P245-60R15 on 15 x 8 on the rear of my Challenger, and they fit - but only with about 3/4" clearance with the wheelwell. That's about the biggest I would go on the rear without any mods.
Re: Cuda Rallye Rim Clearance [Re: Moparmaniacc] #953205
03/18/11 05:24 PM
03/18/11 05:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I got 255/60/15 at all 4's on my 71 Cuda,...that's maxed out on 15X7 rallyes for a Cuda, at full turn the tires "just" start to rub on the frame, the Cuda has a little less clearance than the Challenger in the rear, I tried fitting my Challenger's 275 on the rear, no-way,....... on my Challenger 255/60/15 on the front, and 275/60/15, all Goodyear Eagle GT II's,....check your tire choice amongst other manufacturers, GoodYears of the same size as BFG tend to run slightly larger in thread with, or cross section width
Re: Cuda Rallye Rim Clearance [Re: DAYCLONA] #953206
03/18/11 09:40 PM
03/18/11 09:40 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
I like the look of full wheelwells so I went with 70 series tires. These are on 15x7 rallies. 225/70/15s in front and 255/70/15s in the rear.
Re: Cuda Rallye Rim Clearance [Re: B1arno] #953207
03/19/11 02:52 PM
03/19/11 02:52 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Mike, I have 235/60-15 on front and 255/60-15 on back right now, no issues - new rubber is going to be 245/60-15 all around which is closest to F60-15 hemi E body tire - hope this helps - Joe
Re: Cuda Rallye Rim Clearance [Re: shakerjoe] #953208
03/22/11 11:51 AM
03/22/11 11:51 AM
Essex, Ont., Canada
Fishmarket Offline
Fishmarket  Offline
Essex, Ont., Canada
I've got 15x8 rallyes with 275 60 15 in the back and 235 60 15 in the front, no rubs, lots of room.
Front rims are about 5/16" from the UCA, not counting weights.
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
