Mega Squirt any good?? #952887
03/17/11 11:37 PM
03/17/11 11:37 PM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
I am thinking of going fuel injection on my 383 Big block, to make it look like Hilborn injection. Are they any good and how easy are they to get work?
Thanks Kurt
Re: Mega Squirt any good?? [Re: kams] #952888
03/18/11 11:15 AM
03/18/11 11:15 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I think you should review the forums on the MegaSquirt site. There is a steep learning curve but many people have got them to work just fine. I bought a kit about 6 years ago but ended up selling it before getting into it too deep. If you want to learn all there is to know about EFI and enjoy designing and installing it yourself, and sorting out fuel maps etc it will be a great project.
My guess based on your question is that you might want to look into the EZ EFI by FAST. In the end it will probably cost less.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Mega Squirt any good?? [Re: kams] #952889
03/18/11 12:07 PM
03/18/11 12:07 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Thanks Kurt
MS is fine if you are willing to "join the club". What I mean by that is the system is basically a kit with lots of things to learn, people to talk to, and keep track of. It's an open system which is good if you have the bent toward experimentation and engineering. It is also the least expensive EFI solution and it works very well when implemented properly. Certain things such as sequential injection came to MS late but eventually it does get there.
A note of caution about running stack injection with ANY EFI system. Stack injection should use timed sequential injection. Since there is no single manifold with stacks, you should inject just before the valve opens so that the fuel slug doesn't "pop back" through the throttle plate. This happens only at idle but it can be annoying if you don't run sequential
Sequential injection requires a cam signal in addition to the crank signal. You need either a dual-sync distributor or a separate cam sensor.
Finally, you need to accumulate the vacuum from each stack to generate a map signal to run in speed density. You run 8 rubber lines to an accumulator box and tap into the box for the map sensor. Don't even think about running in Alpha-N.
Re: Mega Squirt any good?? [Re: Mopar_Rich] #952890
03/18/11 12:16 PM
03/18/11 12:16 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Rich a question on the stacks needing timing: The old Hilborn constant flow system didn't have timed injection with stacks. Why the difference with EFI?
Floyd Lippencott IV
Re: Mega Squirt any good?? [Re: mr_340] #952891
03/18/11 12:43 PM
03/18/11 12:43 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Because virtually ALL stack systems were mechanical running alcohol. Alcohol is very forgiving of overly rich conditions and the rich fuel mixture is harder to fire making any pop back minimal. And this happens only at a lower street idle. Step up the idle RPM and it goes away. Finally most stack systems were not for street use, so you tolerated the idiosyncrasies to get the look and the HP.
Nothing but horror stories from people that tried to get a mechanical stack system switched over to gasoline.
Re: Mega Squirt any good?? [Re: Mopar_Rich] #952892
03/18/11 02:21 PM
03/18/11 02:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Check out the megasquirt forums, guys have done all kinds of stuff. Like said, it's the cheapest efi system out there but a steep learning curve and you have to do everything yourself.
Right now the price for the FAST EZ-EFI system for port injection is very competitive, so much so that for the few hundred bucks more it costs over a megasquirt, it's probably worth it for most guys just for the ease of intallation/tuning, even though it doesn't do spark.
Re: Mega Squirt any good?? [Re: DaytonaTurbo] #952893
03/18/11 02:54 PM
03/18/11 02:54 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
Id love to see a current breakdown of the component costs to do a DIY EFI setup, last time I added it all up it was over 2k with no guarantee it would run. Certainly megasquirt on an GM would be cheaper due tothe wide variety of inespensive components available but for a MOPAR its an entirely different game. Just the cost of the fuel rails and welding bungs tothe intake was over $500.
I have my eyes on the FAST setup.
Scott
Re: Mega Squirt any good?? [Re: finadk] #952894
03/18/11 03:53 PM
03/18/11 03:53 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
If you have a port injection manifold the EZ-EFI system looks like this:
EZ-EFI system for port injection $825
4150 throttle body with TPS and IAC $540
Sensors (1 bar map, coolant temp, air temp) $60
Injector pricing depends on the HP level. The only restriction is that they must be high impedance. Can go up to 850 HP depending on the injectors.
If you use the bolt-on EZ-EFI with injectors in the throttle body (bolts on instead of the 4150 style carb), that's $1689. Good for 600 HP.
There are other variations (like 2 TB units) but these are the most common.
Re: Mega Squirt any good?? [Re: Mopar_Rich] #952895
03/18/11 08:02 PM
03/18/11 08:02 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Learning curve isn't as steep as others make it out to be. Yes, it is do it yourself but there is a ton of support and documentation. Plus you can purchase them assembled and tested so that takes out the assembly part of the equation. I have my 83 1 ton running a Holley 670 throttle body with MS2. The VE Analyzer in Tunerstudio does most of the work tuning the fuel maps. Get it running and drive around while it self tunes. Doesn't get much easier than that. I'm using a wideband o2 so that helps as well.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Mega Squirt any good?? [Re: DaytonaTurbo] #952896
03/18/11 09:04 PM
03/18/11 09:04 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Wow I did and your right good thing my kids were not in the room!!!
Re: Mega Squirt any good?? [Re: QuickBpBp] #952897
03/18/11 09:18 PM
03/18/11 09:18 PM
Oh Canada
E
EV2CUDA Offline
EV2CUDA  Offline
E
Oh Canada
http://www.msefi.com/index.php
Other is interesting but not for efi
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: Mega Squirt any good?? [Re: Mopar_Rich] #952898
03/19/11 05:41 PM
03/19/11 05:41 PM
Edmonton, Alberta, Canada
Dartman75 Offline
Dartman75  Offline
The electronics have come down in price, everything else is the same. When I started making my system (2002 planning start) nothing existed below about $2000 and the systems 1/2 as good as FAST's systems were 4000+ and the canadian dollar was not favorable to me by about 1.6 times those numbers. If I could have gotten a system like EZ EFI for 825 bucks, I never would have built my own system. I'd say, skip the pain of learning EFI in and out, and go with a no-science degree required systems. MS is cool, but you'll be frustrated and ultimately give up or wish you have bought a better system by the time you finish.
Re: Mega Squirt any good?? [Re: Mopar_Rich] #952899
03/20/11 09:34 AM
03/20/11 09:34 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
EZ-EFI doesn't support forced induction, MS does.
Something to consider if you are thinking about turbo/blower in the future.
