400 motor, Holley 750 vacuum secondary. If I pull the vacuum hose off the pcv, and the engine speeds up like crazy, could it be anything other than a vacuum leak? I put a vacuum gage on this connection and am getting 15" at idle.
Before, engine used to almost die out if I pulled the hose off the pcv, so I don't know why this is happening now. All I did is pull the carb off, check a few things and put it back together. I doublechecked and I didn't miss any vacuum connections. (No power brakes. Just the one vacuum fitting at the front of the carb plugged off).
Idle mixture too rich?
