Re: Engine Stalling at 60 mph
[Re: duckblind]
#952819
03/17/11 11:21 PM
03/17/11 11:21 PM
RapidRobert
We just put the engine in. Everything runs fine but the engine stalls out at around 60 mph.
More details, was the eng OK b 4 (if so what was changed) or if another eng was it OK w this elec pump setup? Is that cruise or WOT at 60 MPH. What carb? What they said, check float level/filter(s) (inline and carb internal) and might put a T at the carb inlet & run a line to a vacuum gauge taped to your windshield & see if have several PSI at the offending sp (60MPH), Most of the hand held type vac gauges have a PSI side for pumps EDIT read your last post, might put a can of gas in the trunk & run a section of neoprene line down to the line at the sending unit to bypass the tank & take her back out & you'll know immediately if the sock is partly plugged.
[Re: duckblind]
#952822
03/22/11 10:32 AM
03/22/11 10:32 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The problem ended up being a bad fuel pump. Also, the flow out the tank when we had the pump inlet hose disconnected was a little intermittent so we blew back up the line into the tank. After this, it looked like we had better flow. Maybe the sock filter is a bit dirty and that caused the pump to go bad. I guess the next thing on the list of things to do is change the sock filter in the tank to keep this from happening again.
I have a new 3/8 sending unit if ya need one. Also no need for an electric pump on that car. Just go to NAPA and get the pump they have listed for a 440-6 car and roll.
