caltracs and split mono's
#952443
03/17/11 06:00 AM
03/17/11 06:00 AM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
I would like to hear from racers using caltracs, rancho shocks and split mono's on a street car. I have them on my Australian valiant charger. I originaly started out with the rancho shocks set on number 9 position, the car was to stiff in the rear and handled really bad around corners. I changed them to number 5 position and not much better, then to 1 position and the car handles similar to how it was, when original. I wondered what would happen if you have them on the 9 position and your car got sideways at the strip at high speed.
Re: caltracs and split mono's
[Re: 572B1]
#952444
03/17/11 06:24 AM
03/17/11 06:24 AM
Posts: 370 Queensland Australia
moparmacka
Change ya pants is what would happen!! LOL You would have to considerably increase the likleyhood of roll over due to very little suspension movement...... Macka
[Re: 572B1]
#952445
03/17/11 09:41 AM
03/17/11 09:41 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I dunno, never had that happen yet. I don't have much choice though since mine hooks the best w/ em at 9. I typically loosen them up on the street though.
[Re: an8sec70cuda]
#952446
03/17/11 05:55 PM
03/17/11 05:55 PM
572B1
Brisbane Australia
Chip they obviously work well at the strip, but are dangerous on the street, when cornering and going over rough pavement.
I am happy with the product, but you need to loosen bars and shock settings when driving on the street.
[Re: 572B1]
#952447
03/17/11 06:01 PM
03/17/11 06:01 PM
an8sec70cuda
Never had a problem myself. Had them on the car for 8 or 9 years now w/ a LOT of street miles. I never back off the preload on the bars. Saying they are dangerous on the street is a bit of a stretch.
[Re: an8sec70cuda]
#952448
03/17/11 07:16 PM
03/17/11 07:16 PM
BradH
I'm w/ Chip on this, since I have them and run the on-track settings driving on the street, too.
I look at it like this... my Challenger's a street car that's optimized for going fast from a dead stop in a straight line at the track. If I want to go around a corner fast(er) on the street, I park the Challenger and drive my WRX, instead. It's like the old Dirty Harry saying: "A man's got to know his limitations."
[Re: Quicksilver440]
#952452
03/17/11 09:04 PM
03/17/11 09:04 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
i leave my caltracs preloaded.i also found the car rides nicer on the street with ranchos on 5.but on the track i normally use 5 or 6.tyre pressures - i run 30psi on the street,275/60/15 et street radials.i think MT recommend this as a maximum?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#952453
03/17/11 09:36 PM
03/17/11 09:36 PM
572B1
Brisbane Australia
Tex [/quote
Thanks Tex, I have a very lite preload on the bars and the rancho's on setting 5 also. These chargers don't like to be to stiff in the rear. I tried more pre load and the car didn't respond. I also tried ranchos on 9 and the ride was to rough and to much understeer.
I live in the mountains and have 50km of winding roads, its like having your own race track.
