Anyone tow with a hemi? #952292
03/16/11 10:45 PM
03/16/11 10:45 PM
bigfork mn
dragram440 Offline OP
bigfork mn
I am going to look at a 2004 Ram 3500 Dually with a Hemi. I have a 8' pickup camper (2000 lb) that we stay in and pull a open trailer but am planning on getting a enclosed trailer. Do the Hemi's have decent tow power? Diesels are to exspensive to buy and maintain and they dont start good in these minnesota -30F winters. The track is 100 miles one way from my house so I normally arent going to far but I have a 2003 Ford f-250 7.3 diesel short box with air bags and just doesnt seem like enough truck for this setup.
67' charger 499 RB 10.57 at 127
Re: Anyone tow with a hemi? [Re: dragram440] #952293
03/16/11 10:54 PM
03/16/11 10:54 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I'll be following this, as I want to go this route as well.
Re: Anyone tow with a hemi? [Re: dragram440] #952294
03/16/11 10:55 PM
03/16/11 10:55 PM
IN
ahy Offline
ahy  Offline
IN
Yes... tow power is more than decent... but not up to a Cummins. The camper plus open should be easy. The enclosed will give it a workout, especially in head winds. As long as you don't want to fly up hills it should be fine. Expect fuel mileage in the low teens when towing.
Re: Anyone tow with a hemi? [Re: dragram440] #952295
03/16/11 10:58 PM
03/16/11 10:58 PM
johnal Offline
super street
johnal  Offline
super street
had a 2004 1500 that i pulled a box trailer with in the mtns of TN AND NC that thing was a difference and night and day compared to my 01 1500 i had no problems at all just a plain littel hot rod that love to run and pull long since traded it for a cummins dulley just becuase it was a good deal on the truck the hemi and pulling wasnt the issue
Re: Anyone tow with a hemi? [Re: ahy] #952296
03/16/11 10:59 PM
03/16/11 10:59 PM
bigfork mn
bigfork mn
Low teens would be more then awsome for milage. The 8' camper in our 6 1/2 ft short box just makes it hard to hook trailers on and all that wait hanging out the back is just to much.
Re: Anyone tow with a hemi? [Re: dragram440] #952297
03/16/11 11:02 PM
03/16/11 11:02 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
my 04 1500 got 12-13 mpg pulling Elvis from south FL to Cordova, Il on a 22 hr trip. power was fine, the truck was a handful though pulling a 28 footer
Re: Anyone tow with a hemi? [Re: dragram440] #952298
03/16/11 11:12 PM
03/16/11 11:12 PM
Renton Washington
Triple Threat Offline
Renton Washington
Your Powerstroke makes more torque than the Hemi will. I think I would keep what you got and make some changes more to your liking.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Anyone tow with a hemi? [Re: sixpackgut] #952299
03/16/11 11:13 PM
03/16/11 11:13 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
I too have an '04 4wd Hemi and have pulled a 24' enclosed trailer with my Hemi Barracuda inside and a 28' enclosed trailer which was taller than the standard trailer with the same car inside. I went from Indy to Columbus, Ohio both times and didn't have any problems. Didn't check the gas mileage because I didn't care, I figured it got what it got. The Cummins diesel would be far superior but for my daily work truck the Hemi does just fine. Hey, does that Hemi have a Hemi? Yup.
Re: Anyone tow with a hemi? [Re: sixpackgut] #952300
03/16/11 11:14 PM
03/16/11 11:14 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
04 1500 4x4 hemi 24 ft enclosed
WAXER
Re: Anyone tow with a hemi? [Re: Triple Threat] #952301
03/16/11 11:22 PM
03/16/11 11:22 PM
bigfork mn
bigfork mn
I will still have the Ford. I have 5000 lb air bags in it, Edge programmer and 10 ply tires. It sways and doesnt seem to have any weight on the front tires.
Re: Anyone tow with a hemi? [Re: QWK_ENUF] #952302
03/16/11 11:27 PM
03/16/11 11:27 PM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Had a 2005 Hemi 4wd.Towed a 32ft trailer from Toledo,ohio to KC,Mo.Towed ok,it was the stoping that was hard.
Re: Anyone tow with a hemi? [Re: dragram440] #952303
03/16/11 11:29 PM
03/16/11 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm sure with the camper you would need frame extensions
with a EQ hitch... the hemi might not lie all the frontage
and the weight of the camper
Re: Anyone tow with a hemi? [Re: dragram440] #952304
03/16/11 11:32 PM
03/16/11 11:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a EQ hitch on it to lift the rear of the truck
back up to the normal height
Re: Anyone tow with a hemi? [Re: MR_P_BODY] #952305
03/16/11 11:44 PM
03/16/11 11:44 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I've got an '03 Ram long bed DRW. We carry an 11ft camper in the 8ft bed while towing an 18ft open trailer.
This is the hitch I've used for the past 8 years without any problems.
The only towing system designed specifically for truck campers! If you have trouble towing with your truck camper because it extends past the end of the truck bed, this is the solution! Patented extended hitch system is engineered for towing all types of trailers, boat or personal watercraft. Dual receiver with compression tube. Extension towing capacity up to 12,000 lbs. Designed for campers up to 12'. Two piece system. Order hitch to fit the year, make and model of your truck. Then, select extension by length and carrying capacity needed.
http://www.adventurerv.net/torklift-superhitch-p-5102.html
Re: Anyone tow with a hemi? [Re: dragram440] #952306
03/17/11 12:11 AM
03/17/11 12:11 AM
kalamazoo, MI.
VIPERDUST Offline
VIPERDUST  Offline
kalamazoo, MI.
Had a 04 4x4 with Hemi, pulling 26 foot enclosed on flat Mich. roads, 8-10 is the max I ever got. Low teens is dreaming.
Re: Anyone tow with a hemi? [Re: VIPERDUST] #952307
03/17/11 12:30 AM
03/17/11 12:30 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I currently have the 06 Ram 2500 4x4 hemi, use it as a tow vehicle and daily driver/work truck.. The truck itself weighs in at just over 7000 lbs empty.. With work stuff, its easily close to 8000...
Towing the Duster in a 24' enclosed trailer, I have easily towed over 10,000 miles in these short 4+ years of ownership..
The power of the hemi while towing can easily pass any slower vehicle and on most hills, we can keep a steady 55 mph while on cruise control.. For the large mountain grades, you do have to crank up the motor to keep up speed, but I dont think I have ever slowed to less that 45 mph on the steepest grades..
Gas mileage is dissapointing.. empty on the freeway, it gets 13-14 mpg.. around town loaded with work stuff, its a solid 10 mpg.. towing on flat land we can squeak out low 12's, but towing up n down the mountains we're lucky to get 8!!
All I can say is I wish I had a Cummins.. but I dont, so would I buy another Ram hemi?? heck yeah..
Re: Anyone tow with a hemi? [Re: Jeepmon] #952308
03/17/11 01:08 AM
03/17/11 01:08 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have a 2004 Hemi ram 1500 I installed 4.56 in the rear. tows great
Re: Anyone tow with a hemi? [Re: 70blackfish] #952309
03/17/11 01:22 AM
03/17/11 01:22 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I would think a cummins is a better choice but at least your looking at a 3500 dually. You'll like the way it tows, handling and stopping . Can't say about mileage, my cummins gets about twelve with the 28 footer loaded at 70 mph.
Re: Anyone tow with a hemi? [Re: rowin4] #952310
03/18/11 10:02 AM
03/18/11 10:02 AM
bigfork mn
bigfork mn
Well I picked it up yesterday.
My Charger will look better towed by A Dodge rather then A ford!
Uploaded with ImageShack.us
Re: Anyone tow with a hemi? [Re: dragram440] #952311
03/18/11 10:18 AM
03/18/11 10:18 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
I have a 8ft bed '03 2500 hemi. It tows pretty good. With an open trailer and the barracuda loaded I get 14 - 15mpg. I just brought the new 28' enclosed home last weekend empty and it towed nicely although I did keep it out of overdrive. We'll see how she does loaded up!
