Convertible Cuda 70 Map Light Wire With No Switch #949819
03/13/11 11:45 AM
03/13/11 11:45 AM
Wausau Wi
Convertcuda Offline OP
Wausau Wi
Need your help. The tag fell off my Map Light Wire for my convertible cuda. Does anyone have reference on this tag for part number and vendor number.Would really like a nice clear pic of an original. Remember this map light does not come with the switch so the number will be different. Thanks Ken
Re: Convertible Cuda 70 Map Light Wire With No Switch [Re: Convertcuda] #949820
03/15/11 07:51 PM
03/15/11 07:51 PM
CA
moparman70 Offline
moparman70  Offline
CA
I just happen to have my dash apart and pulled the map light harness out but the white tag was too far gone to make out any numbers. Its still there but almost turning to powder. I found the tag right at the end closes to the connections just where the tape ends... but again can't make out any numbers.
Re: Convertible Cuda 70 Map Light Wire With No Switch [Re: moparman70] #949821
03/15/11 09:33 PM
03/15/11 09:33 PM
Wausau Wi
Wausau Wi
Sometimes you can unwrap the lable and see the other underneath.
