440 truck block dipstick tube location #949381
03/12/11 06:13 PM
03/12/11 06:13 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Is there anyone who is familiar with using a 440 truck or rv block that can tell me if the oil dipstick hole is just blocked with a plug on the engine block or do you have to drill it out yourself, the truck oil pan has the dipstick mounted right into the pan and you can not use this pan on a car, Thanks, Rodger
Re: 440 truck block dipstick tube location [Re: 69 GTX] #949382
03/12/11 07:25 PM
03/12/11 07:25 PM
WI Goodrich 54411 USA
Chaaargerb Offline
Chaaargerb  Offline
All the Big Block motorhome motors and truck motors I have worked with all had a steel plug in the block. I think if you take a small screw driver and pop them out. I just take a punch from the bottom side when the pan is off.
Re: 440 truck block dipstick tube location [Re: Chaaargerb] #949383
03/12/11 07:47 PM
03/12/11 07:47 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Thanks very much, pulled the pan and punched it out, it was in pretty tight,
