Know where I can get GOOD T/A pushrods? #949230
03/12/11 02:17 PM
03/12/11 02:17 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
They're longer than standard small block pushrods because of the T/A offset intakes.
I'd gotten a couple replacement pushrods from Comp Cams years ago and both had the cup receiver snap off! I'm just glad they didn't fall down into the engine!
Re: Know where I can get GOOD T/A pushrods? [Re: T/A CARe] #949231
03/12/11 02:23 PM
03/12/11 02:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Measure the situation for your motor and get them from Smith Bros.
Re: Know where I can get GOOD T/A pushrods? [Re: autoxcuda] #949232
03/12/11 02:26 PM
03/12/11 02:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I agree, Smith Bros or Manton....
http://www.pushrods.net/
http://www.mantonpushrods.com/
Re: Know where I can get GOOD T/A pushrods? [Re: T/A CARe] #949233
03/12/11 02:36 PM
03/12/11 02:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Was the cup hitting the bottom of the rocker?
When Troy did his T/A motor he had some sort of pushrod length issue. IIRC, not all lifters have thier pungers in the same place. Or lifter plungers in the past have been in different places. The adjuster screws weren't in the right place.
Re: Know where I can get GOOD T/A pushrods? [Re: autoxcuda] #949234
03/12/11 03:41 PM
03/12/11 03:41 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
I "think" that's what was happening. With the longer than stock rods (7.5625) vs. stock (7.4375) the adjustment screw & ball had to be farther up in the rocker, allowing the pushrod cup to hit the bottom of the rocker...
I have used shorter rods (7.25) which cause a little too steep an angle as the ball enters the lifter and chews up the end. (See pic) Thoughts?
The original T/A rod is on top.
I'll look up the links above and see what they say.
Re: Know where I can get GOOD T/A pushrods? [Re: T/A CARe] #949235
03/12/11 04:38 PM
03/12/11 04:38 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You need a length checking pushrod , with 2 threads of the adjuster showing out of the bottom of the rocker that will be the length pushrod you need , if the heads and the block have been decked a lot you would need a shorter pushrod .
Re: Know where I can get GOOD T/A pushrods? [Re: JohnRR] #949236
03/12/11 04:41 PM
03/12/11 04:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Like this...
Re: Know where I can get GOOD T/A pushrods? [Re: autoxcuda] #949237
03/12/11 07:10 PM
03/12/11 07:10 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
Thanks guys!
