Re: Shimming K-Frame for Carb Clearance [Re: racingblues1426] #947754
03/12/11 12:44 AM
03/12/11 12:44 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used 5/8" thick 3x2 spacers in my b body for years. It will change the steering geometry. It was still the easiest fix for installing a crossram and using double pumper carbs that needed 1/2" spacers so the carb would open and close properly. Have your alignment rechecked and a slight steering difference will be noticed. I would do it again in a heartbeat. Arlen Vanke told me that all original hemi dart and cudas used this trick for hood clearance. Good luck
What geometry are you referring to?
Bump steer is determined by lower control arm pivot/lower ball joint vs inner and outer tie rod assy. None of this relationship is changed by shimming the k-frame lower. Yes the camber curve changes but is really a non issue in a car of this type and use.
Doug
Re: Shimming K-Frame for Carb Clearance [Re: Old School] #947755
03/12/11 12:45 AM
03/12/11 12:45 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Why not just mill the single plane intake down, im sure the lose of plenum volume would help it more then hurt it. Redrill the carb holes and tap them and your all set. You still have a single plane intake and it fits under your stock hood.
Re: Shimming K-Frame for Carb Clearance [Re: ChrgrCuda] #947756
03/12/11 12:53 AM
03/12/11 12:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thank you sir. Seeing how the engine and tranny aren't even in yet, it has to go to the alignment shop anyway, as I am starting from scratch.
Can you go to a front motor plate.... then you can
lower it the needed amount and leave the K where it is
If you do go to lowering the K I would go with shock
extensions also otherwise you will loose travel
Re: Shimming K-Frame for Carb Clearance [Re: Old School] #947757
03/12/11 12:14 PM
03/12/11 12:14 PM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
1/2" spacers, and it still will not fit under the hood. you will need to loose about 1 1/2- 2",for it to fit under your stock hood. i've tried this already on my cars....
Thanks for the replies Old School. Nick did say that after the shimming of the K-member if it still requires clearance that we would then probably mill the intake. As Nick said, there is more then one way to skin a cat.
I want to also extend my thanks to everyone for all the informative and helpful replies on this post as well as another post. Your experience and wisdom has been my guide in this endeavor of my first B-body big block car.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Shimming K-Frame for Carb Clearance [Re: ChrgrCuda] #947758
03/12/11 02:02 PM
03/12/11 02:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Another thing you can do to minimize effect on suspension geometry is use FMJ spindles, they are taller than B body spindles so they compensate for lengthening the other side of the box...
Re: Shimming K-Frame for Carb Clearance [Re: 1_WILD_RT] #947759
03/13/11 12:25 AM
03/13/11 12:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree, they are aprox 3/8" taller. Good move.
Doug
