Shimming K-Frame for Carb Clearance #947734
03/10/11 03:07 PM
03/10/11 03:07 PM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
Has anybody here ever tried to shim or make spacers between the K-Frame and body for extra hood clearance? This is for my 69 Charger, and I'm being told that my RB440 w/Indy intake will not clear the stock hood. However, Nick at Compuflow told me it would. I thought I had an Indy 2-D intake, but it's the Indy single plane. I hope I don't have to change out my already powder coated brand new, milled MW port intake.......
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Shimming K-Frame for Carb Clearance [Re: ChrgrCuda] #947735
03/10/11 03:24 PM
03/10/11 03:24 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i have 2 chargers and 2 cudas. i have to use a k&n flow control, drop aircleaner in all the cars. that is even using the indy dualplane. the singleplane is about 1 1/2" taller. they will not fit under any of my stock hoods. i do not know your combo, but that dualplane is the best one made. i have dynoed many intakes, and it almost always makes more torque. i even have one for my 580" motor.
you might consider the mopar 337 manifold. it is a singleplane and will fit under the hood. it is very close to the performance of the indy. i have also dynoed both of them. again it all depends on the combo. i'm assuming you have a 500" motor?
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Shimming K-Frame for Carb Clearance [Re: ChrgrCuda] #947736
03/10/11 03:38 PM
03/10/11 03:38 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Shimming the k-member will alter your suspension geometry, as the upper control arms are mounted to the frame and not the k-member so their relation ship would change.
It will also change your pinion angle, as the motor will drop relative to the transmission mount, raising the tail shaft of the transmission.
Re: Shimming K-Frame for Carb Clearance [Re: ProStDodge] #947737
03/10/11 03:44 PM
03/10/11 03:44 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
done it lots of times, but only 1/2in. anything more than that I have no info on.
Russ
Re: Shimming K-Frame for Carb Clearance [Re: ChrgrCuda] #947738
03/10/11 03:45 PM
03/10/11 03:45 PM
Out West
408strokerdart Offline
Out West
You don't want to do that on your car for the previously stated reason. I would check clearance first, but I am almost sure you will have a problem. I thought you were getting the 2D intake until I took the single plane to the powder coater.
Re: Shimming K-Frame for Carb Clearance [Re: ProStDodge] #947739
03/10/11 03:55 PM
03/10/11 03:55 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Shimming the k-member will alter your suspension geometry, as the upper control arms are mounted to the frame and not the k-member to their relation ship would change.
It will also drop your steering box further away from the column and change that angle too.
Re: Shimming K-Frame for Carb Clearance [Re: old_racer] #947740
03/10/11 04:05 PM
03/10/11 04:05 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Use PM or E-mail or post in the Swap Meet Area
Mopar Performance
Re: Shimming K-Frame for Carb Clearance [Re: Old School] #947741
03/10/11 05:01 PM
03/10/11 05:01 PM
Texas, USA
Texas, USA
Yes, I have a 505 RB in the Charger. Looks like I'll have to send this one back.........
Re: Shimming K-Frame for Carb Clearance [Re: ChrgrCuda] #947742
03/10/11 05:40 PM
03/10/11 05:40 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Ron (firefighter3931) did this with his 68 Charger,,,no issues,,turned out fine,
Not sure on the amount he spaced the K frame,,,hopefully he see's this post and reponds,,,,
you might consider sending him a PM,,,,good guy.
Doug
Re: Shimming K-Frame for Carb Clearance [Re: 69CHARGERMD] #947743
03/10/11 06:01 PM
03/10/11 06:01 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
Not to hijack the post BUT do you think using ½ spacers would help weight transfer . I’m always trying to make my 9 inch Hoosiers stick better
Re: Shimming K-Frame for Carb Clearance [Re: sjs64polara] #947744
03/10/11 06:58 PM
03/10/11 06:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You'd be moving a little weight up (not much) but
the biggest weight(engine) is still in the same place
Re: Shimming K-Frame for Carb Clearance [Re: MR_P_BODY] #947745
03/10/11 09:15 PM
03/10/11 09:15 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
You're right Guess I'm just dreaming and wishing happy thoughts
Re: Shimming K-Frame for Carb Clearance [Re: moparniac] #947746
03/10/11 09:18 PM
03/10/11 09:18 PM
Texas, USA
Texas, USA
You have a PM Sledge
Re: Shimming K-Frame for Carb Clearance [Re: ChrgrCuda] #947747
03/10/11 10:17 PM
03/10/11 10:17 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I have spaced the K down on a couple of cars. I had to drop the tranny mount the same amount on one but not the other. And I just loosened the steering column flange at the firewall and let it slide down a little for the steering.
As for the suspension, I just had the car re-aligned.
No big deal. Worked fine.
Master, again and still
Re: Shimming K-Frame for Carb Clearance [Re: DaveRS23] #947748
03/10/11 10:35 PM
03/10/11 10:35 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
The 68 factory superstocks did it without issues and since an A-Body is and A-Body ......no big deal . Even did that with my MagForce front end . So far the car`s gone 139 and change . No Problems .
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Shimming K-Frame for Carb Clearance [Re: chryco] #947749
03/11/11 06:45 PM
03/11/11 06:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've done it on B-bodys. I also did the alignments. It will cause camber to go negative due to the fact that the upper arms have to angle downward the additional 1/2". Some cars have enough adustment to compensate,some don't. It does not effect bump steer.
Doug
Re: Shimming K-Frame for Carb Clearance [Re: dvw] #947750
03/11/11 07:25 PM
03/11/11 07:25 PM
Texas, USA
Texas, USA
Thanks Doug. I have the CAP tubular LCA's if that makes any difference.
Re: Shimming K-Frame for Carb Clearance [Re: ChrgrCuda] #947751
03/11/11 07:40 PM
03/11/11 07:40 PM
mogadore ohio 44260
racingblues1426 Offline
mogadore ohio 44260
I used 5/8" thick 3x2 spacers in my b body for years. It will change the steering geometry. It was still the easiest fix for installing a crossram and using double pumper carbs that needed 1/2" spacers so the carb would open and close properly. Have your alignment rechecked and a slight steering difference will be noticed. I would do it again in a heartbeat. Arlen Vanke told me that all original hemi dart and cudas used this trick for hood clearance. Good luck
Re: Shimming K-Frame for Carb Clearance [Re: racingblues1426] #947752
03/11/11 09:16 PM
03/11/11 09:16 PM
Texas, USA
Texas, USA
Thank you sir. Seeing how the engine and tranny aren't even in yet, it has to go to the alignment shop anyway, as I am starting from scratch.
Re: Shimming K-Frame for Carb Clearance [Re: ChrgrCuda] #947753
03/12/11 12:13 AM
03/12/11 12:13 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
1/2" spacers, and it still will not fit under the hood. you will need to loose about 1 1/2- 2",for it to fit under your stock hood. i've tried this already on my cars....
