Re: a little help w a lift off hood
[Re: fishy340]
#947208
03/09/11 07:51 PM
03/09/11 07:51 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I used moroso brackets,springs,and buttons.Worked out nice but just did a custom rail for 2000 Firebird for his lift off and would do that instead now.I like the way it looks and can put fastners where I want and can contour the hood better.Don't use alum rivets I made that mistake and lost the hood a 120 or so.The rivets sheared after 30 or 40 passes.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: HEMIFRED]
#947214
03/09/11 08:58 PM
03/09/11 08:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Regular pins are BESTer .... and far more durable and more holding "power". And if the hood is made right and braced properly ....you don't need that many of them.
Dzuz are slow on slow off and prone to making you scratch the paint no matter how hard you try not to do it. pins are my choice especially in case of an emergency like seeing smoke
But they are UGLY............ JMO
[Re: dOc …]
#947215
03/09/11 09:02 PM
03/09/11 09:02 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Damn BigCube ... it must take you 20 minutes to get all those fasteners loose to get hood off ! ...and it sure looks like you could have used one of those hoods with the rear cowl section.
The cowl covers the removable panel, plus it's a good place to hide the gauges. The way my chassis was built the stock vent grate was a leak into the interior. The removable panel also closed off a water leak AND made room for the air cleaner.
[Re: snook]
#947219
03/09/11 11:52 PM
03/09/11 11:52 PM
Posts: 30,487 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
Much as I hate to agree with Doc Fibberglass, I have to go with pins as well. My Dzus adventure would have killed someone had I not been as far down the track when they let go.
Pins from here on out for me. Ugly? Maybe. Safe? Definitely.
HATE to agree with 'da Doc ?
You should be HAPPY .... you are finally doing-some clear-thinking ..
[Re: Bigcube]
#947220
03/09/11 11:55 PM
03/09/11 11:55 PM
dOc …
Florida STAYcation
YOU have almost as many gauges as that GUY with the 63 BELLveeDEER ....
[Re: dOc …]
#947221
03/09/11 11:57 PM
03/09/11 11:57 PM
Bigcube
Upstate NY
But I hide them better
[Re: Bigcube]
#947223
03/10/11 12:05 AM
03/10/11 12:05 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
heres what I did fwiw, and yeah easy to scratch the paint with the dzuz
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: dOc …]
#947224
03/10/11 12:11 AM
03/10/11 12:11 AM
MR_P_BODY
On a serious note ....
I have seen single Dzus (on the corners) ...and then the whole SYSTEM fails and the whole panel exits the vehicle ... because there is so little holding-strength on a single Dzus.
I'll be using Dzus on my new hood... I use more than 4, my hood on the P has 10 was 12 with the old hood with the scoop attached but the scoop is separate now and mounts to the engine(with 3 Dzus) but its slow only 150
[Re: MR_P_BODY]
#947225
03/10/11 01:37 AM
03/10/11 01:37 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have 4 Areocatch latches on the fiberglass deck lid on my 70 cuda, have them for the hood also but have not installed them yet. No pins or screw drivers to scratch your paint. I put a set of 4 on my buddy's chevy hood , it has a multi thousand dollar paint job. he loves them. He runs high 8"s at 150+ . Now with my paint job , a person would question my sanity. Great product, got them off e-bay from MiataRoadster.
[Re: rowin4]
#947226
03/10/11 02:10 AM
03/10/11 02:10 AM
MR_P_BODY
I always liked them... but they're pretty pricey
