Re: 1993 Chrysler Concorde 3.5L Cooling fan constantly runs
[Re: EasyG]
#946258
03/08/11 02:43 PM
03/08/11 02:43 PM
Posts: 905 SD
zrxkawboy
SD
Unplug the AC pressure switch that screws into the hard line below the condenser.
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#946260
03/11/11 04:05 PM
03/11/11 04:05 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I had the same problem with my 94 LHS.
Do not exactly remember the exact fix but it is related to the AC circuit.
There is a pressure sensor that tells the computer the AC is in demand. During this condition the computer tells the fans to run to cool the condenser.
I remember replacing a pressure switch and it's a very smart set up. The switch pushes on a Schrader valve so you don't lose freon when you unscrew it.
[Re: Magnum]
#946261
03/14/11 01:23 PM
03/14/11 01:23 PM
Posts: 10,644 S.E.Ohio
Magnumguy
S.E.Ohio
Where is this switch located? My cooling fan will trip the check engine light on occasion, and I notice it's not running, mine, like y'alls, seems to be operating all the time when it does work.
[Re: Magnumguy]
#946262
03/16/11 10:55 AM
03/16/11 10:55 AM
Magnum
Sorry, it's been years since I swapped the switch. I only remember it being right on an AC line.
