I used LA intake gaskets when mounting my LA intake to Magnum heads. The difference is in the bolt holes I think.
Use Remflex or similar gaskets between your headers and the head. There is very little common gasket area between the LA headers and the bottoms of the Magnum port (about 1/8" wide maximum sealing area if I recall), they will want to leak there.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
