ID/INFO on Shifter Mounting Plate #945946
03/08/11 12:22 AM
03/08/11 12:22 AM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline OP
This was in a box in the trunk of a 68 coronet r/t i purchase, actually was mounted to tail shaft,in trunk with box full of 833 parts,its a hurst mounting plate with the name hurst 6350 on back side, is this right mounting plate for a 68 b body coronet 4 speed? Thanks
Re: ID/INFO on Shifter Mounting Plate [Re: 268RTs4ME] #945947
03/08/11 12:23 AM
03/08/11 12:23 AM
2
pic 2
Re: ID/INFO on Shifter Mounting Plate [Re: 268RTs4ME] #945948
03/08/11 08:45 AM
03/08/11 08:45 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I'm not sure which it is but I know it's not the B body one.
Re: ID/INFO on Shifter Mounting Plate [Re: JohnRR] #945949
03/08/11 10:56 AM
03/08/11 10:56 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
The plate in question is A body, for a 64-70 B you need either 2297 or 6348.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
