Re: Drag Pak Engines [Re: STEFF] #945701
03/09/11 03:57 PM
03/09/11 03:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice Bullet!!!!
BLING BLING
Rich H.
Esse Quam Videri
Re: Drag Pak Engines [Re: ZIPPY] #945702
03/09/11 11:39 PM
03/09/11 11:39 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
GT/TB index is 10.85
10.5 X 305HP = 3202 + 170 driver = 3372 at the scales after a run
so it needs to run 9.60-9.80s to be competitive. Currently an A/SA runs 10.0s (some faster) out of most chally stockers with a 6.1
so i think a 5.7 rated at 305hp Superstocker can get it done at 3372.
any takers?
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Drag Pak Engines [Re: Locomotion] #945703
03/11/11 11:51 AM
03/11/11 11:51 AM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
I have seen both Mark and Jeffs cars and realize that they are running the drag pak engines. Even talked to Jeff about this at Indy. My info came from Bruce Bachelder, NHRA Tech services, at the Southerns. As I understood it, the rule was put in place because there were some late model LS1 or LT1 firebirds that ran with the same motor and the Formula scooped hood with different HP rating so they ruled that the hood and engines could not be mixed. Looks like they have at least changed to allowing air engines in non air cars in SSGT, maybe both ways by now.
I would still check with NHRA before I built an engine/body combo for SSGT.
Re: Drag Pak Engines [Re: SC304] #945704
03/11/11 03:10 PM
03/11/11 03:10 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
This project has been a long time coming and would not have been possible without my partners Dave,Kyle and Rock.
You need to light a fire under Dave's butt so he finishes his Mustang!
Can't wait to see the Challenger completed at the track.
Re: Drag Pak Engines [Re: Blusmbl] #945705
03/11/11 06:38 PM
03/11/11 06:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Personally I can't wait to make a pass in it.
Doug
Re: Drag Pak Engines [Re: dvw] #945706
08/19/11 06:40 PM
08/19/11 06:40 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
Bump
